Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 02-07-2013, 11:14 AM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
FS: Non-M Stoptech BBK - $1100 w/new pads and almost new rotors
Sold
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 02-08-2013, 11:49 AM   #2
bigjae1976
bigjae1976's Avatar
bump
Old 02-09-2013, 05:54 PM   #3
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
I'm pretty sure this will bolt up to a 325/328. GLWS brotha!
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 02-09-2013, 09:47 PM   #4
bigjae1976
bigjae1976's Avatar
Yup...but this specific kit was spec'd for a 330. I also have a 323/5/8 rear Stoptech BBK
Old 02-12-2013, 09:43 PM   #5
bigjae1976
bigjae1976's Avatar
Bump
Old 02-14-2013, 01:31 AM   #6
bigjae1976
bigjae1976's Avatar
ttt
Old 02-14-2013, 12:25 PM   #7
crazyxzer0
My Ride: 2004 330i
Send a message via AIM to crazyxzer0 Send a message via MSN to crazyxzer0
Does this clear 17 inch rims?
-Derek
Stoptech Front BBK|M3 LSD|GC Coilovers w/ Swift Springs|UUC TSE3 Exhaust|
My Build Thread
crazyxzer0 is offline   Reply With Quote
Old 02-14-2013, 12:53 PM   #8
bigjae1976
bigjae1976's Avatar
Depends. I know they clear APEX ARC8 17x9 ET42 and Dforce LTW5 17x9 et41. They do not clear the OEM 17" M68s. The VMR CSL reps need a 5mm spacer.
Old 02-15-2013, 09:25 AM   #9
bigjae1976
bigjae1976's Avatar
Bump. I've got 330 brakes...just need to sell the kit.
Old 02-16-2013, 06:58 AM   #10
Projekt330s
My Ride: 2004 BMW 330i
Bump! I would be on this if I weren't buying coils thanks for the fuel filter
Projekt330s is offline   Reply With Quote
Old 02-16-2013, 12:52 PM   #11
bigjae1976
bigjae1976's Avatar
ttt
Old 02-16-2013, 01:19 PM   #12
Steven747
My Ride: 05 330ci
curious what you were using for the rear? just stock? i guess the rear upgrade isint really needed.
Old 02-16-2013, 01:22 PM   #13
bigjae1976
bigjae1976's Avatar
The ST BBK for a 323/5/8. You lose the parking brake...forever.
Old 02-16-2013, 10:22 PM   #14
chivo328
My Ride: 328/330/633/M5
I have a 4 wheel StopTech kit on my 328 and still have a parking brake.
chivo328 is offline   Reply With Quote
Old 02-16-2013, 11:28 PM   #15
bigjae1976
bigjae1976's Avatar
That's because the 330 has a larger diamater drum. So the smaller drum for the 328 kit hits the metal tab on the trailing arm which the parking brake level pushes against. So you have to cut it off and grind it smooth. Once you do that, no more parking brake.
Old 02-17-2013, 03:41 AM   #16
crazyxzer0
My Ride: 2004 330i
How much clearance was there on the 17x9? I got the 17x8.5 +40..
Shame you are parting the car. Did the harness I sold you work out for you before then?
-Derek
My Build Thread
Old 02-17-2013, 05:22 AM   #17
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Will it fit an M. Would it be suitable for an M?
Do you ride a sportbike?
Old 02-17-2013, 08:08 AM   #18
bigjae1976
bigjae1976's Avatar
I guess that was a long time ago? I guess they did...I've been happy!
Not a really recent pic but this is with the ARC8 17x9 ET40. The LTW5 has a little more inner diameter and spoke clearance. I've replaced the rotor discs since this pic (for everyone).
Not sure. I would imagine not. You could part out the rotors and brackets and then buy the 355mm rotors and new brackets...Cost would be about $1100-$1200?
Old 02-18-2013, 05:21 PM   #19
bigjae1976
bigjae1976's Avatar
bump
Old 02-19-2013, 08:12 PM   #20
Trashcan
My Ride: 2002 330ci
Do you have pictures of everything off the car in current condition?
Trashcan is offline   Reply With Quote
