#1 |
Coding question...did wife get it right?
Just installed siren/tilt sensor in my wifes 330Ci, and we're waiting for a BMW scanner to arrive so I can do the coding to enable it myself. In the meantime my wife called the dealer (where's the trust!?!
) about them enabling the alarm I installed and changing programming on a couple of items. She says that the service advisor she talked to told her that if she brings it in to them to program ($185) that they will also update all of the computer modules in the car. Now she's hot to take it in so she is up-to-date. BS? Hadn't heard this before. Car has not had any computer update since April 2007, a 2006 vintage update related to the computer not trapping emissions system malfunctions. (SI B12 06 06 Engine Electrical Systems June 2006.) Appreciate any feedback. |
#2 |
Platinum Plus Quality
Even if you had the "scanner," I highly doubt you'll be able to update the DME. Further, if your wife's 330ci flashes when locking/unlocking, programming for alarm is already enabled.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#3 | |
http://forum.e46fanatics.com/showthr...893444&page=65 The car did not have an alarm on it and was not enabled, I've confirmed that. There is a setting to flash the lights when an alarm is not installed, that's all she has now. Would appreciate feedback on my question...whether there is any substance/value to a SW update as a part of the programming by the BMW dealer. Last edited by Redflea; 02-07-2013 at 03:20 PM. |
#4 |
My car didn't have the alarm, lights did blink when locking and unlocking, I installed the alarm, and it works just fine without programming at all. And damn that siren is loud.
![]() Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight= ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight= |
#5 | |
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs Last edited by Mango; 02-07-2013 at 03:55 PM. Reason: Auto-save 1360274141 |
#6 | ||
The first page in this thread has a good illustration of the screens/actions it supports... http://forum.e46fanatics.com/showthr...893444&page=65 |
#7 |
The only way I was able to enable the optical confirmation while locking and unlocking was to change the coding to say it was equipped with an alarm.
#8 | |
#9 |
Slightly Modded ///Member
Why not ask the dealer what updates have come out since 2007?
If they're selling you something they should be able to tell you what it is. If they can't, then you know it's BS. |
#10 |
Listen to E46 Mango....if you get a K+DCAN cable that hooks up to USB, then you can download BMW standard tools for free (INPA, NCS Expert, Tool 32, and WinKFP) and do all the programming yourself....like he said, with the right Daten V41 files (I have them and can link you to where to get them), and with the proper part number, you can update and program all you want...also have a battery charger connected...do all this at your own expense though...if you brick it, you are going to have to buy a new DME and then still pay BMW to program it
#11 |
^+1 and be especially careful with MS45 DMEs when updating them. They say they are particularly sensitive to voltage spikes/drops during programming and you'll end up w/ a brick. Ask Terra!
#12 | |
The dealer will probably have to hook their equipment up to your car to determine which software version you currently have in each of your modules. They will then be able to tell you if your current versions update but not necessarily how many times or even what the updates correct. I think it's a good deal for $185 if they do ALL control units. Plus if something goes wrong and they brick one of your modules, it's on them. |
#13 |
I didn't talk to the dealer, wife made the initial call, but she basically was told what shoelit said - depends on what has been updated in the past. My wife could have given them her VIN and asked them to look it up, but she didn't have the time at the time.
But...all this is for naught, unfortunately, it's been taken out of my hands. My wife has decided that she isn't willing to wait any longer and is taking her vert into the dealer on Monday for them to program. She's got a streak of impatience to her, so I'm not too surprised. ![]() Thanks, Mango, for the comment about upgrading using winkfp - I wasn't aware of that capability w/the K+DCAN cable. I'm still reading up on coding options (have an e39 as well) in my currently very limited spare time. I'm very interested to see how the PA Soft works when it arrives in a few weeks. If I had known about the K+DCAN option first, I probably would have gone that way, but I didn't come across the K+DCAN info until just a couple of days ago. I do have one remaining question - I can test the alarm on my e39 easily as it has a motion sensor in the car. Vert does not. The e39 will also provide a brief chirp if get in the car, set the alarm, turn off the motion sensor, and then start the car w/the key. What's the best way to test the alarm on a vert? Aside from jacking it up, is there a way to set off the alarm once it's armed, aside from breaking a window or something? Thanks for all the help. |
#14 |
Sit in the car, lock/arm the car. Then open the door with th door handle...that should set it off, I think
#15 | |
My Ride: '94 325iC & '00 323i
Among systems with errant messages is the SRS (airbag system), there are others, but this one comes to mind as an example. NOBODY will know what firmware your car is running with without doing a data dump to see. Getting the car reflashed is usually a good idea, but I'm thinking the price is rather high. This is a job that should take Shop Rate for one hour -- the actual job takes about 5 minutes. They can code the alarm at the same time. |
#16 |
#17 | |
Close the doors, lock the car. Try opening the car or hit it a couple of times with your hand (flat, not your fist). Nothing will happen though. The alarm has to be coded ON else it will not do anything. |
#18 | |
Another test for you... Roll the window down and lock the door from outside, then reach in and start the car. It will not start. |
#19 | |
#20 | |
I think it has to do w/the programmable setting that allows you to disable the alarm via remote and key, or just remote. On my e39 it appears the option to disable via both key and remote are enabled. |
