#21 |
My Ride: '94 325iC & '00 323i
Try locking the car with the key, not the remote. My E36 does not start when I lock it with the key. This is my second E36, and they both behave this way. My daughter has an E46 that I'm pretty sure behaves this way, but I can't say for certain.
I would want my car to disable the starter circuit whether it was locked by the key or the remote, but if it disabled the starter by locking and not by the remote, then I'd not be happy with the way the remote works. We know that Factory Fitment has the car disable the starter when locked with the key. That's a standard feature. If you have a remote that does not disable the starter, then I don''t know where to do from here, but I _think_ something is amiss. Put the window down and lock the car using the key in the door lock, then reach in through the open window and see what happens when you try to start the car. |
#22 | |
Grand Superpatriot
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#23 |
#24 |
as far as i remember, if the clown nose blinks when the car is armed and the lights blink with lock and unlock, the WHOLE alarm is activated.
2002 325xi Sport 5 speed Euro clears, short shifter, style 119 wheels
2002 GMC Envoy SLT (stock) |
#25 |
#26 |
All you need to do to test the alarm is open the hood with the alarm armed. It will go off.
![]() Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight= ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight= |
#27 | |
As mango said, a DME update would take about 45 mins. Possibly longer for an MS45 car OP: Just buy a VAG 409.1 interface and the Ediabas suite, and do the coding yourself. It's quite easy, a lot cheaper than what the dealer wants, and allows you to do so much more This is not necessarily true. In fact I would say its more likely the alarm isn't enabled of the retrofit was never done Last edited by TerraPhantm; 02-08-2013 at 09:41 AM. |
#28 | |
When I was researching coding, for some reason I only initially found the threads talking about the "BMW 1.4 scanner" options...Based on some posts I saw, similar to these two (http://forum.e46fanatics.com/showpos...0&postcount=11, and http://forum.e46fanatics.com/showpos...5&postcount=14) I decided to try the "Scanner 1.4" option. I didn't run into the Eiabas side of things until later, after I had ordered. So I'd like to wait for the one I've ordered to come in before I order more stuff, and in the meantime my wife has decided she just doesn't want to wait any longer - she's gotten it into her head that we can't park her car anywhere but at her parking garage work or at home until she has the alarm enabled. (I've shown her that the car is immobilized when she locks it, but she wants a the noise maker going if someone messes with it.) Her money, and she brings home just a little more than I do annually (bless her!), so her decision. I am interested in the Ediabas option, and have been looking at this thread (http://forum.e46fanatics.com/showthr...hlight=ediabas) and this connector that it suggests (http://www.ebay.com/itm/BMW-USB-OBD-...9&cmd=ViewItem) which appears to come w/everything that I would need to go that route. What's considered the best thread (here or other forums) to figure out coding e46 using the Ediabas suite/vag interface? |
#29 | |
Grand Superpatriot
#30 |
I would actually check out http://www.bmwcoding.com/forum.php |
#31 |
#32 |
Dont take it to the dealer....you should be able to do everything with your BMW Scanner...I own one and enabled all the features myself. As far as the updating the ecm goes its BS. Thats something they throw in there to seal the deal and it usually works. How do they know if your wife has already had the update? They dont...so they just throw that in there to justify the high price to activate the alarm which literally takes 10 minutes to do.
Just some advice from myself and others who had this happen to. When you take your car to activate the alarm they will in purpose deactivate a feature you already had enabled in order to get you back in and charge you some more. I had my windows opening with remote feature deactivated when I took my car and others had other features deactivated like unlocking passenger door with remote. They are notorious for doing this and its sad that they are getting away with it. First time I took my car to the dealer and they ripped me off. After that I purchased the BMW scanner and did everything myself. BMW updates to software dont do **** anyways...
#33 | |
Also BMW scanner is somewhat dangerous. Way too easy to screw up a module with it. INPA and NCS Expert are better for 99% of the things you can do. They give you much finer control and it's easy to recover from any mistake. The only thing I use BMW scanner for is changing VINs on certain modules. The average owner shouldn't need to do that. DME and transmission updates absolutely do help if one is available. On MS45 cars for example, the more recent updates largely diminished the 4000RPM dip and 2800RPM stutter. It's not worth $180 when you can do it yourself for free, but to say it doesn't do **** is misleading. Last edited by TerraPhantm; 02-08-2013 at 11:41 AM. |
#34 |
I don't recall my '00 323 taking 45 minutes to update, but whatever. If you can acquire the software and hardware (connectors and such) to update the car for anywhere near what the dealer charges for the procedure, then you are money ahead if you buy the stuff it takes. Why rent for an hour when you can own for life?
I paid to have my car updated because I was new to the E46, and didn't know I could have done this myself. I was having a host or troubles with a used car that I got for a song and repaired with an $80-dollar solenoid and the diagnostic charge, so I came away okay. Knowing what I know now, I would have bought the diagnostic package. |
#35 | |
They seem to require registration to just view posts, which is kind of annoying. Going to register now and look around there. |
#36 | |
#37 | |
So my $40 bmw scanner lets me change options without defaulting the other settings but their 4k scanner doesnt?
If this is true and they know it then why don't they just enable everything that was enabled before when you came in? Instead they leave it that way and charge you again to take a look at the problem? ![]() Either way it happens...deliberately or not. Quote:
