Old 02-07-2013, 03:30 PM   #1
joedan
My Ride: 323ci
Cold start hard to put in the gear in manual
Hi guys,
I have a BMW 323ci been rolling for about 205000km. I live in Sweden and the temperature here is around -10degrees Celsius at the moment.
My problem is that recently when it was freezingly cold, one day when I started my car and tried to put in reverse it was almost impossible to put it in. It was not going into the gear position. And once I got it in by force! I shifted gear to first gear and it too was hard to shift into. When the car started rolling and engine is warm it was no problem to put in any gear.
Any ideas what it could be?
Thanks,
Joe
joedan is offline   Reply With Quote
Old 02-07-2013, 03:32 PM   #2
white46
My Ride: e46 323ci
I would try changing tranny fluid with Redline D4 ATF.
white46 is offline   Reply With Quote
Old 02-07-2013, 04:09 PM   #3
joedan
My Ride: 323ci
@white46 do you mean you think it might help to change the transmission oil? I am not sure if my car uses transmission oil separately from engine oil or is it the same?
Old 02-07-2013, 04:15 PM   #4
michalt95
My Ride: 02 325i MT
Transmission and the engine do not share the same oil. They are 2 different objects. They are only connected by a shaft.
You have engine oil in you engine and you have transmission oil in your transmission.
michalt95 is offline   Reply With Quote
Old 02-07-2013, 04:21 PM   #5
joedan
My Ride: 323ci
Ok thanks, in the manual it says transmission oil is life time:
"Manual transmission, automatic transmission and differential
Lifetime fluid, no fluid change required"
You think that I need to change the engine oil? The display in the car actually says it's about 14000km until next oil service due.
Old 02-07-2013, 05:39 PM   #6
michalt95
My Ride: 02 325i MT
Your engine oil and transmission oil have nothing to do with each other. BMW says that the manual transmission fluid is lifetime however people recommend to change it. Do some research on this forum. This topic about changing the trans fluid has been covered many times.
transmission
