Old 02-07-2013, 04:56 PM   #1
bronxbomerss2
My Ride: 05 325CI
Send a message via AIM to bronxbomerss2
TCU won't pair
Hey guys just got a tcu off ebay the tcu is part # is 84116946993 which has been confirmed to have Bluetooth I purchases the Bluetooth antenna that goes under the center console as well as the new Bluetooth mic. I did purchase the ses jumper cable but didn't need.it since I could find the blue cable that goes to it . So I know the tcu doesn't need a paring button it.goes.into.pairing mode.once the car.is on the only cable that I connected is the black one on the tcu and the cream beige connector but when I press the R/T button on the steering.wheel it says phone book empty and when I search for Bluetooth devices.on my cell phone nothing comes.up !! Any help would be greatly appreciated guys !! Also I have a 05 325ci which didn't have assist or Bluetooth previously . I'm open to all suggestions I have searched all over but don't know what else to do or look for.
Sent from my ADR6300 using Bimmer App
bronxbomerss2 is offline   Reply With Quote
Old 02-07-2013, 10:13 PM   #2
Cazz
My Ride: 2005 BMW M3
Did you put your phone in pairing mode and then turn the key in the ignition?
The car should search for a BT device to pair with for 1 or 2 minutes.
If the phone see it, you should be prompted for the 4 digit passcode.
Cazz is offline   Reply With Quote
Old 02-08-2013, 03:13 AM   #3
bronxbomerss2
My Ride: 05 325CI
yeah i put the phone in discoverable as well as search for BT devices but nothing came up also tried with 3 other phones and nothing!
Old 04-12-2013, 06:48 AM   #4
mavric315
My Ride: 2004 330xi
Did you every solve this? I am having the same issue.. I have a 2004 330xi with Assist. I swapped out the TCU for a 94.10.9195455 TCU and added in the BT antenna under arm rest. The jumper pre-installed on the blue connector. I have all cables connected (beige/purple, black/purple, and blue/purple along with large black connector on rear) as in the pictures shown and no go. I even got the resler ibus adapter and checked that the TCU can communicated with an it can be coded (BT is enabled and I enabled voice). Still nothing will pair with it. Turn ignition to pos 2 (or even start the car) and as I understand it should enter pairing mode for two minutes. Nope. Turn car off for 1 minute and repeat.. Nothing.. Double checked antenna connections and even put phone(s) on top of TCU.. No joy... Any help would be appreciated...
Thanks!
-Don
mavric315 is offline   Reply With Quote
Old 04-12-2013, 06:51 AM   #5
mavric315
My Ride: 2004 330xi
Whoops that should have read 84.10.9195455 TCU..
-Don
