Old 02-07-2013, 06:54 PM   #1
honkifyoubonk
My Ride: E 6666
Need help with which ccv kit to buy
One is for cold climate package? I believe my car has the cold weather package ( headlight washers/heated seats) but I'm wondering what the difference in the actual fitment is?
http://www.oembimmerparts.com/produc...itoeme46cc.htm
http://www.oembimmerparts.com/produc...skitoeme46.htm
^ obviously this doesn't come with the valve, but in the description it states " not for models with cold climate version"
Mango/jfrof where ya at?
Thanks-
honkifyoubonk is offline   Reply With Quote
Old 02-07-2013, 07:45 PM   #2
nike001
My Ride: Fergo
The Cold Climate version is the same as the other one, only the cold climate version as insulation around the hoses.
You don't need a certain package to run it, nor does your car need to be in a 'cold climate' all it's life. It's just insulation around the hoses that gives it it's name. The insulation is supposed to help condensation and moisture buildup from freezing up and blowing out your ccv
2015 M235i 6MT
nike001 is offline   Reply With Quote
Old 02-07-2013, 07:53 PM   #3
330iPilot
My Ride: Titanium Silver 330i
Thanks-
If you don't live in a cold climate then you could get by with the regular version no problem. From what I hear it's easier to install too.
330iPilot is offline   Reply With Quote
Old 02-07-2013, 10:06 PM   #4
honkifyoubonk
My Ride: E 6666
Thanks guys!
Old 02-08-2013, 06:31 AM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Not knowing where you are makes it difficult to say if you need cold weather version or not...if you're in Canada or Siberia...probably a good idea. It is a pitb getting it in with the foam. I got cold weather kit and removed insulation from it. My old one was regular and it did fine. So far, years later, I'm still fine.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-08-2013, 06:58 AM   #6
nike001
My Ride: Fergo
The cold climate one is also pretty much the revised version
2015 M235i 6MT
Old 02-08-2013, 08:01 AM   #7
honkifyoubonk
My Ride: E 6666
I live in the Midwest so I will get the cold weather one and if its to much of a pain ill just remove the insulation thanks
Old 02-08-2013, 08:17 AM   #8
330iPilot
You don't need it unless you live above the South Dakota line
