Sponsored by The Tire Rack
Old 02-07-2013, 07:41 PM   #1
Zell
Wears carbon fiber boxers
Zell's Avatar
My Ride: 330Ci ZHP 6sp
Center rear tire wear
I am noticing I am having a little more center rear tire wear than the front. The fronts look brand-new, but the rears definitely are wearing more in the center than the outside tread.
I've recently had an alignment and balance, and I have meticulously followed the BMW tire pressure rules as indicated on the door jamb:
32 PSI front
38 PSI rear
What could cause this, and how can I prevent it from getting worse?
I don't track, I don't have a lead-foot, I don't spin out my tires (if ever), I don't drive hard. I'm just your standard, regular driver.
I've had the tires for about a year now. Potenza RE760s, standard ZHP staggered sizes (225 front, 255 rear). I want to catch this before it gets bad.
E46Fanatic's resident mathemagician
Old 02-07-2013, 08:09 PM   #2
HiHoBrian
My Ride: 05 M3
Your can lower your rear tire pressure a bit. And also you can verify the width of your wheels and the size of your tires. If the wheels are on the narrow end of tolerance for your tire fitment it will bulge the tire and increase center wear.
255's should be on a 8.5" wheel for proper fitment. If the wheel is norrower it will bulge. 8" wide wheel is probably ok,7.5 would likely cause accelerated wear. That's where I would look first.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 02-07-2013, 08:41 PM   #3
Zell
Zell's Avatar
Fronts are 8", rears are 8.5"
I'll try dropping to 36 psi and hope for the best. I've seen other people with this problem as well but no one has talking about any solution. Some claim RTABs but would RTABs cause inner tire wear? I'd expect something like outer.
Old 02-07-2013, 09:29 PM   #4
djantlive
My Ride: E46 M3
Do you have a lot of stuff in the trunk or take rear passengers?
djantlive is offline   Reply With Quote
Old 02-07-2013, 10:13 PM   #5
Zell
Zell's Avatar
Nope, just me myself and I, and I've got my car cover in the trunk
Old 02-08-2013, 12:31 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: 1:25 Scale Enzo
I'd lower the tire pressure in the rear just a bit.
Kevin @ VMR | Wheels
Tel: 714-442-7916 | Email: kevin.a@velocitymotoring.com
Facebook! | Flickr! | Blog!
Old 02-08-2013, 11:03 PM   #7
Zell
Zell's Avatar
Thanks guys. I lowered to 36. Think I should stick there, or go to 34 on all corners?
Old 02-09-2013, 12:44 AM   #8
paraklas
paraklas's Avatar
My Ride: ESS TS2 320ci
I have perfect tire wear with 33PSI front / 36PSI rear pressure, 225/40/18 front and 255/35/18 rear
http://www.argyrides.eu/makeyourownsig.jpg
Old 05-12-2013, 08:53 AM   #9
themoth
My Ride: BMW 325 ci
Would this be the right set up for style 42 17 inch staggered set up, currently running the below set up. Thinking about changing to the above
Front: 225 45 17 35psi
Back: 245 40 17 36psi
Thoughts
themoth is offline   Reply With Quote
