Sponsored by BimmerWorld
Old 02-07-2013, 09:41 PM   #1
mynewe45ride
My Ride: E46/328i/199k
Help with strut install
I am installing koni orange WITH H&r springs. How tight should the top nut be? I tried as much as i can by holding the nut via socket & vice grip and using a hex key with pliers. I still some gap at the bottom of top plate & shaft where there is 45 deg slope. I am attaching pics. One side is slant so i know i got to redo to align. The nut is definately pita. Koni uses 22 mm nut as compared to 21mm stock.
Sent from my DROID4 using Bimmer App
My ride - 99/328i, Manual
2011 - window regulator, vcg, vanos seals, fuel filter, PS hoses+resorvoir, water pump, wp pulley, belts, thermostat, spark plugs, springs, FCAB & RCAB
2012 - Driver & Passenger Seat Belt Tensioner
2013 - Rear Diff & subframe bushing, Shocks & Struts, Wheels
2014 - Belts, Pulleys
2015 - Brake Pads/Rotor Front-Back
2016 - Fuel Pump
2017 - Upper & lower intake boot
mynewe45ride is offline   Reply With Quote
Old 02-07-2013, 09:44 PM   #2
mynewe45ride
More pic as bimmer app keeps crashing on my droid. Its not allowing me to upload more than 1 pic.
2016 - Fuel Pump
Old 02-07-2013, 09:46 PM   #3
mynewe45ride
Top view. Top of shaft is flush with top nut.
2016 - Fuel Pump
Old 02-07-2013, 10:02 PM   #4
///MPR77
My Ride: 02 ///M3 Tri-Ped
You want it pretty tight.
Do what you can while its on the ground, and finish tightening after its all back togehter.
Once installed:
Use an Allen through the Socket, and a clamp on the socket, and vise grips on the Allen, and tighten.
GL.
Old 02-07-2013, 10:05 PM   #5
bernie21614
My Ride: 01 330i
Doesn't look right, there should be about 3 or 4 threads on top of the nut after its tight, you need to keep the spring compressed while you tighten that top nut.
bernie21614 is offline   Reply With Quote
Old 02-07-2013, 10:55 PM   #6
pleiades
My Ride: M52TU
Once installed:
GL.
+1. The nut should tighten properly once you have the strut assembly installed and the car on the ground.
If getting a 22 mm socket in there is the problem, Harbor Freight sells a 22 mm (7/8-inch) O2 sensor socket for a few bucks that you can sand down and fit in there quite well while counterholding with an allen key through the center.
pleiades is offline   Reply With Quote
Old 02-07-2013, 11:20 PM   #7
hanna
My Ride: BMW 328i
I used an impact wrench with a regular (non impact, thinner) 22 mm socket. It's the easiest way, no need for vice grips,etc..
hanna is offline   Reply With Quote
Old 02-07-2013, 11:24 PM   #8
mynewe45ride
Txs for the tips. I got it tight by duck taping a 40 coarse sandpaper on the 22mm deep socket. Then used a c-clamp to tighten it. I got 3 to 4 threads on the top and bottom slope fits tightly. I will check it once i bring her to ground.
2016 - Fuel Pump
Old 02-07-2013, 11:26 PM   #9
mynewe45ride
Btw, still used a hex key with pliers to tighten it holding the c clamp. One tip that helped was to hold the strut mount instead of c-clamp when tightening with hex key.
2016 - Fuel Pump
Old 02-07-2013, 11:27 PM   #10
mynewe45ride
Final pic from the bottom.
2016 - Fuel Pump
Old 02-07-2013, 11:29 PM   #11
pleiades
My Ride: M52TU
It's also the way that strut installation guides typically warn against using to tighten the upper strut nut.
Old 02-07-2013, 11:31 PM   #12
///MPR77
Exactly.
Glad it worked out OP.
Old 02-07-2013, 11:33 PM   #13
fth001
My Ride: 325i, e36m3, s13
Or you could spend $30 and save you alot of problems by buying a pass-thru socket set.
fth001 is offline   Reply With Quote
Old 02-08-2013, 08:04 PM   #14
genuity
My Ride: 2001 330iS
I am surprised the inverted hex in the center threaded rod of the strut did not strip before you hit torque spec. If anyone ever has Bilsteins and does this, it will surely strip. I wasted all this money getting special sockets and what not to only have it still strip. Ask me how I know Just save yourself some time and impact it on. Meyle end links also uses this retarded design.
genuity is offline   Reply With Quote
Old 02-09-2013, 06:45 PM   #15
hanna
My Ride: BMW 328i
Yeah, impact works perfect, just do not hammer on it for 5 minutes, zip it and done
