Old 02-07-2013, 11:01 PM   #1
gselsidi
My Ride: 2005 325i M56
vanos oil line leaking
Hello,
The vanos oil line by the solenoid is leaking at the top. Can only the top portion be replaced instead of the whole line? Some diy were pretty involved.
gselsidi is offline   Reply With Quote
Old 02-07-2013, 11:04 PM   #2
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
If it's the one I'm thinking of just order some new crush washers. Then remove it and replace the washers.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 02-07-2013, 11:04 PM   #3
TurnersInOz
My Ride: 2004 325i
Nope, it is one piece.
Make sure though that it isn't just loose, or the crush washers.
TurnersInOz is offline   Reply With Quote
Old 02-07-2013, 11:11 PM   #4
pleiades
My Ride: M52TU
If you're asking about an e46 with an M52 or M54 engine (and not about the VTEC line on your Acura....), I'd say this.
The Vanos line is a seamless rubber line with two metal crimped ends. If it's leaking from the banjo bolts themselves, replacing the washers -might- help, but they're not really crush washers in the conventional sense (they don't crush).
Usually when they get old (from heat cycles) these lines "weep" from the edges of the metal crimps where the rubber starts. The lines are about $30+ each. You probably need a 19 mm offset box wrench for the rear connection to the back of the OFH. Of course will need to move the airbox out of the way to get to that one, but it's doable. Torque to spec.
pleiades is offline   Reply With Quote
Old 02-07-2013, 11:15 PM   #5
gselsidi
M56 posted pic
Sent from my SGH-T889 using Bimmer App
Old 02-07-2013, 11:17 PM   #6
TurnersInOz
My Ride: 2004 325i
Looks to me like a new VANOS oil line and four new crush washers are in your future.
Old 02-07-2013, 11:22 PM   #7
pleiades
My Ride: M52TU
Originally Posted by gselsidi View Post
M56 posted pic
Okay, ignore my post, I know nothing about the M56. Thanks for updating your car info, I was wondering why you had it listed as an Acura....
Old 02-07-2013, 11:25 PM   #8
gselsidi
Yeah sorry I just never changed the car lol
Old 02-07-2013, 11:29 PM   #9
gselsidi
Naaaooooo!! Anyway everybody says pop off the air box. Any diy for removing only the washers? And what part numbers are the washers?
Old 02-07-2013, 11:31 PM   #10
gselsidi
What is a banjo bolt? And can you only replace it?
Old 02-07-2013, 11:53 PM   #11
gselsidi
Harp mehs? I figured out what the banjo is. Bmw replaced the solenoid under warranty would they use new crushers?
Also there is oil by the banjo im assuming oil cant travel up the line to contaminate the banjo?
Third what kind of washers do I need can I get them at the hardware store?
Old 02-08-2013, 12:03 AM   #12
Stinger9
My Ride: '04 330Ci
Supposed to use new crush washers each time you remove them. Yes, they do crush.
How do we know what your dealer does?
Specialty washers; get the right ones for BMW.
Wipe really clean and see where the oil comes from.
I'd replace the oil hose and 4 crushes.
Old 02-08-2013, 12:14 AM   #13
gselsidi
Yeah I plan on cleaning it. Is idleing the engine enough to cause it to leak again? Or would I need to drive it. What are the washers called? Where can I buy some. Also from the picture I took the banjo looks old or maybe its from the oil.
Old 02-08-2013, 01:14 AM   #14
Stinger9
My Ride: '04 330Ci
You should learn how to use www.realoem.com to get part numbers for your car.
Then check out these vendors to shop for prices.
WWW.furiousmethod.com
Idling oil pressure will show up leaks. Might take a while as the hose fail weeps slowly at first.
