Old 02-08-2013, 12:25 PM   #1
Jemmacandili
My Ride: BMW 325ci 2001
Engine service soon
What's the meaning of this? Is something wrong with the car? Is it bad? Like something's broken? Thank you
Jemmacandili is offline   Reply With Quote
Old 02-08-2013, 12:27 PM   #2
matchee
My Ride: 2000 328i
Can you tell us year make and model? You can have the codes pulled free at Autozone or Advanced or about any autoparts store for free...
matchee is offline   Reply With Quote
Old 02-08-2013, 12:27 PM   #3
ngillan
My Ride: Is in a salvage yard
Usually has something to do with the air in your tires...Did you put winter air in when it started getting cold outside? I would check this first, if not then move on to blinker fluid levels...
but for real...what matchee said
'07 328i - Montego Blue
ngillan is offline   Reply With Quote
Old 02-08-2013, 12:29 PM   #4
Jemmacandili
It's a 2001 325ci.
Old 02-08-2013, 12:30 PM   #5
JJR4884
My Ride: BMW
i've had issues with this before as well, however the last time my check engine light went on, it was because someone was in the act of stealing my engine. luckily i stopped them, and the light went off
OP, is anyone trying to take your engine? i would double check just to be sure...
JJR4884 is offline   Reply With Quote
Old 02-08-2013, 12:30 PM   #6
Jemmacandili
Do autozone give you the code for free? They can really so that?
Old 02-08-2013, 12:33 PM   #7
Jemmacandili
No one trying to get my engine. Lol
Check engine light is the same as engine service soon?
Old 02-08-2013, 12:34 PM   #8
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Outback
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
yes and yes
VALMONT is offline   Reply With Quote
Old 02-08-2013, 12:34 PM   #9
JJR4884
My Ride: BMW
i have a feeling that today is going to be a very informative, yet, humbling day for you my child.
absorb everything this thread gives you, good and bad, sleep on it, and then see how you feel tomorrow
Old 02-08-2013, 12:35 PM   #10
matchee
My Ride: 2000 328i
Yes for free...
They will even let you clear them out if you ask.
Old 02-08-2013, 12:38 PM   #11
Jemmacandili
Guys you think they can tell me what's wrong with my car why it has engine service soon light on it?
Old 02-08-2013, 12:43 PM   #12
matchee
My Ride: 2000 328i
They will tell you what the codes say - unless they are generic codes and then you will have to write them down and look them up.
This is probably the most honest answer you are going to get so get to Autozone and start from there...
Could be anything from gas cap to fuel delivery to ignition problems.
Old 02-08-2013, 12:45 PM   #13
JJR4884
My Ride: BMW
Take a deep breath, and call them
Not very bright are we? Some places will do it and some won't. If I remember correctly, most places won't do it because there is some liability, and probably because they aren't making a dime off of you. If they do it, they usually print out the code and what the definition of that code is. o2 sensor, bank 1 running lean, secondary air pump failure... etc
Here is some advice, and I want you to listen closely because you are asking questions like a high school girl who doesn't know what to wear for prom. Find a place that will run a code, get the code, go to google and search what that code typically means.
If you come back here and give several possibilities of what you found, as a responsible and independent adolescent like yourself, I can guarantee you will get much more help from members here than what you are getting.
Seriously shut your goddamn computer off and go find the answer, and we will discuss when you return.
Old 02-08-2013, 12:53 PM   #14
Jemmacandili
Cause it really drives me crazy, I'm kinda scared for what is happening to my car right now.
Sometimes it's really hard to start up the car. And this past few days its always like that. I went to Arizona to check my battery and alternator they said its good.
Worst things happening to me is the engine shuts off when I'm stopping like in the stop light. Something like that's it just shuts off automatically.
What do you think is the problem? Help me guys!
Old 02-08-2013, 12:55 PM   #15
Jemmacandili
Old 02-08-2013, 12:57 PM   #16
matchee
My Ride: 2000 328i
Oh thanks for the pic- that helps
Old 02-08-2013, 12:57 PM   #17
Jemmacandili
Okay I will do that, this is my first time here really appreciate the help! Thank you I will call few autozones nearby thank you
Old 02-08-2013, 12:59 PM   #18
ngillan
LOL!
Looks like you blew the welds on your intake manifold. Granny shiftin', not double clutchin' like you should.
Old 02-08-2013, 01:04 PM   #19
NukeMiller
My Ride: 2005 325i
There is a reason these guys are working at autozone and not for a SAE reputable shop....take thier advice with a grain of salt and come back to this thread with the codes
NukeMiller is offline   Reply With Quote
Old 02-08-2013, 01:12 PM   #20
JJR4884
My Ride: BMW
Is OP a female? sounds like one...
