Old 02-08-2013, 01:00 PM   #1
slow330
My Ride: 330ci
330ci which 30lb injectors to use SC
I searched and came to find out so many different opinions!
For a E46 which injector are you guys using! Seem most people use the
Red top ford motorsport 0 280 160 945
But do these fit plug and play!
Since they come in older cars!
Which one do do use!
And please provide with a part #
Tune will be set at 8.5psi. Thanks
slow330 is offline   Reply With Quote
Old 02-08-2013, 01:37 PM   #2
joshzhp
My Ride: ZHP--Stock
Search Trippinbimmer..he had several sets for sale.
joshzhp is offline   Reply With Quote
Old 02-08-2013, 01:44 PM   #3
TrippinBimmer
My Ride: Just Fast!
I Have some gm 33lbs will work fine. Linked it in ur old thread
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 02-08-2013, 02:05 PM   #4
mike@maximumpsi
My Ride: 02M3T
I would stop searching and talk to the company that is providing your software. Many injectors will flow enough fuel, yet are not optimal for your application.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 02-08-2013, 02:08 PM   #5
joshzhp
My Ride: ZHP--Stock
It is all about the tune....I am beating a dead horse here.
Old 02-08-2013, 03:26 PM   #6
slow330
My Ride: 330ci
Am refering more to the type of plug(clip) that will fit. Ev1/Ev6
The tuner said bosch 30lb
Injectors.
Old 02-08-2013, 03:49 PM   #7
TrippinBimmer
My Ride: Just Fast!
Injectors.
Either EV1/EV6 body style is fine but want the Jetronic/Mintimer connector and not the Uscar ones. I can included the mounting hardware if need as the bosch sit higher then oem injectors...
Alpine White M3
MaximumPSI Stage4
