Sponsored by BimmerWorld
Old 03-01-2013, 08:28 PM   #1
330iBlue
My Ride: 05 330i
Brake oil leak???
Proud to say I changed pads and rotor for the first time ever. I did the driver side first, then the passenger. While I had passenger side up, I notice a small puddle of light color oil on the driver side under the fuel filter. It was very clear, so I am pretty sure it was brake oil. The oil level is normal and the brakes work fine. Is it possible that when I pressed the caliper piston back in, I caused some sort of back flow. Is that possible???
330iBlue is offline   Reply With Quote
Old 03-01-2013, 08:50 PM   #2
lcoleman
My Ride: '79 Massey Ferguson
Yes, but it comes out the reservoir when that happens. Get under the car and inspect for leaks... it's just a hard metal line(s) in that area. Keep an eye on your brake fluid, too, of course.
Old 03-01-2013, 09:11 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Look in the area below brake fluid reservoir. If you spilled brake fluid, you should rinse it off...it's very corrosive to paint...probably other things too.
But, I wouldn't be surprised if it's not brake fluid...or if it is, maybe you just spilled some.
If it's possibly coming from a brake line, you should inspect thoroughly.
I haven't read of one brake line ever going bad here. Only guys replacing them seem to be tracking the car.
Anyway, doublecheck everything. If you're not sure still, just ask a neighbor of yours casually if he'd like to try driving your car.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 03-01-2013, 09:44 PM   #4
330iBlue
My Ride: 05 330i
I think it is coming from the reservoir. The top seems to be wet like it was over filled with out me adding any. I drove around and feels ok. I will keep an eye on level. Thanks guys.
Old 03-01-2013, 10:03 PM   #5
dmax
dmax's Avatar
When you push the piston in with new pad, it pushes the fluid up. Clean up the spills off the paint.
Mangofy your E46!
Old 03-01-2013, 10:12 PM   #6
choxor
My Ride: JDM
Yup. That one thing to be very aware of: brake fluid will absolutely 100% ruin your paint.
