Sponsored by The Tire Rack
Old 02-08-2013, 06:12 PM   #1
Poncho@home
My Ride: MY04 330Cic ZSP
Stainless steel wheel bolts
Any issues using stainless steel wheel bolts? Could they seize up after some time, since they are a different alloy?
Some are for sale locally for $40, so,I was thinking of getting them
Poncho@home is offline   Reply With Quote
Old 02-08-2013, 06:18 PM   #2
epistaxis2008
My Ride: 2002 330ci
Anti seize (that aluminum liquid stuff in the little gray can that has the built in paint brush under the lid like nail polish that u can find at any auto store) should help. Verify its ok on lugs first though. You don't want your tire flying off on the highway.
Sent from my PG86100 using Bimmer App
epistaxis2008 is offline   Reply With Quote
Old 02-13-2013, 02:23 PM   #3
James @ Saad Racing
Past Site Sponsor
You need to check what the hardness of the bolts you are replacing versus the stainless steel bolts. In general, a stainless bolt is equal to a grade 5 standard or an 8.8 in metric.
There are a couple of factors that go into a bolt and/or nut seizing.
Over torquing
Heat cycles
Rusting
Soft bolt/nut (grade 2 or less)
You are worried about over torquing mostly. The stainless bolt will not rust, but the mating hole will.
Torque will differ with different bolt sizes, hardness, length and thread pitches. Check with the supplier of the bolts and see if they have a recommended torque spec. If you have those numbers, I can give you a torque range for the bolt
No worries on anti seize. It will not allow the lug to "loosen up". It will help with corrosion resistance and allow for a more consistent torque too.
Hope this helps
Last edited by James @ Saad Racing; 02-13-2013 at 02:38 PM. Reason: Auto-save 1360787893
James @ Saad Racing is offline   Reply With Quote
Old 02-13-2013, 07:52 PM   #4
Poncho@home
Thanks James, very helpful. I decided against buying them. Mostly for cosmetic reasons, not mechanical. My current wheels have darker inner spokes, where the lug bolts are, so I think the SS bolts would "clash"
I will stay with OEM style "black" lug bolts for now.
Old 02-14-2013, 08:11 PM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
The black lug bolts don't look too bad anyway so I think that's a good choice.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
