Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 02-10-2013, 06:27 AM   #1
scott_karana
My Ride: E46 325i Sport
Unhappy Factory headunit broken after removing to check what kind of pins it has?!
Hey guys;
Just like the title says. Planning on getting an aftermarket deck, so I pulled my factory headunit (CD53?) to see whether it had the flat or round pins.
When I next ran the car, I couldn't get anything out of the radio:
  • No clock, or anything else on the display
  • No audio
  • No anti-theft light
The only indication that I even plugged the connector back in is that I can see the faceplate light up when my headlights are on.
I tried pulling it again, checked the connector and the built-in fuse above it, and everything looks good...
Any ideas? Was it just that I forgot to unhook the battery before pulling it the first time?
Happy to pull it again if part numbers or photos help.
Also, possibly related is the fact that I removed my glove compartment to test out of my fuel pump relay, and removed the GM5 to get a better reach. However, central locking and fuel are working fine afterwards; the car is in complete running order except for the damn radio.
Is there even anything in that area that I could have forgotten which would make it stop working? I wouldn't know.
Last edited by scott_karana; 02-10-2013 at 06:31 AM. Reason: dashboard -> glove compartment
scott_karana is offline   Reply With Quote
Old 02-11-2013, 03:12 PM   #2
scott_karana
Nobody has any ideas at all?
Old 02-11-2013, 03:19 PM   #3
linom3
My Ride: M3
fuse blown maybe?
linom3 is offline   Reply With Quote
Old 02-11-2013, 03:19 PM   #4
linom3
My Ride: M3
radio conector no plug in all the way?
Old 02-11-2013, 07:26 PM   #5
mrbamathews
My Ride: 02 BMW 325i
Follow a simple diag tree here
1. check all fuses
2. remove radio & make sure pins on the back of the radio are not bent/ damaged
3. make sure wiring connector is/ was fully seated & clipped into place
mrbamathews is offline   Reply With Quote
Old 02-12-2013, 07:14 PM   #6
scott_karana
Yup, turned out to be a mis-positioned fuse in the main box.
Thanks All!
