E46 Xi Forum
Old 02-10-2013, 10:40 AM   #1
032
My Ride: '03 330xi
55k Miles '03 330xi
So I'm looking at an '03 330xi automatic with 55k miles on it. The price is $10,795 from a dealership, and I think I could get them down to $9,800. What are some typical problems that people have in the 50k-100k mileage range? What should I ask the mechanic to look for? Cosmetically, the car looks excellent, which may be a sign of a careful owner. After all, he only drove about 5-6,000 miles annually.
032 is offline   Reply With Quote
Old 02-10-2013, 10:49 AM   #2
Bmwdad
My Ride: 2003 M3
Somewhere around 60k I had to do a ccv job. Then at 70k oil filter housing gasket and oil level sensor. Other than that I knew vanos should most likely be next. Is this a BMW dealership. If not the are all rather easy DIY and I don't like jus anyone working on my car.
Bmwdad is offline   Reply With Quote
Old 02-10-2013, 11:06 AM   #3
032
My Ride: '03 330xi
Ok, thanks a lot. I've heard that something usually goes with the coolant system around 60-70k. I'm trying to gather a list for what my mechanic should look at. Right now, we're at:
Coolant system
VANOS
Transmission fluid
CCV
Oil filter housing
Anything else that I should have him check out? I'm assuming the battery has been replaced, but maybe I need a third battery, as I'm told they last between 5-7 years.
Old 02-10-2013, 11:17 AM   #4
My325XI
My Ride: 03 325XI Sprt Prem
add Valve cover gasket and brakes.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 02-10-2013, 11:45 AM   #5
032
My Ride: '03 330xi
thanks, anyone else have anything he should check? also, are there any specifics about anything listed that I may need to tell the mechanic? he knows I'm a laymen, but I'd like to provide a detailed request.
Old 02-10-2013, 11:56 AM   #6
Dreamliner330
My Ride: 330xi
I'd have him check the front CV joints for sure. 10k isn't a bad price for a well taken care of low mileage one owner. A lot of people overlook condition and blanket statement that every non m should be 6k.
Dreamliner330 is online now   Reply With Quote
Old 02-10-2013, 01:11 PM   #7
032
My Ride: '03 330xi
Ok, thanks. Updated list:
Coolant system
VANOS
Transmission fluid
CCV
Oil filter housing
Front CV joints
Valve cover gasket
Brakes
Any other additional things would be much appreciated.
Old 02-10-2013, 02:03 PM   #8
Kubica
My Ride: 2003 325xi
Get it on the highway going as fast as possible and check for vibrations.
Old 02-10-2013, 07:11 PM   #9
032
My Ride: '03 330xi
Thanks! I just checked the CARFAX, strangely there were three owners, but it doesn't seem to be an issue. The oil was changed every 3,500 miles, the front wiper blades were replaced, the "sensor" was replaced (don't know which sensor specifically), the air intake hose was replaced, and so was the cabin air filter. It doesn't say anywhere that the battery was ever replaced, but I've heard they typically only last 5-7 years. As always, does anyone have anything I should add to the list of specifics for the mechanic to check out?
Old 02-10-2013, 09:29 PM   #10
E46@46
My Ride: 2003 325xiT
IMO that sounds like a great deal. I bought my 2003 325xiT with 145k. So 55k miles seems like a pup. If you have documentation of the oils changes then you can deal with anything else that comes up. However, on the other hand sometimes too few miles means a lot of short trips that can cause other problems. I'd rather have 100k miles on all highway than 55k on city driving. Good luck...
E46@46 is offline   Reply With Quote
Old 02-10-2013, 11:00 PM   #11
032
My Ride: '03 330xi
Thanks, and every owner has been from NJ, so I'm assuming very little city driving, and more highway driving.
Old 02-11-2013, 12:11 PM   #12
SamDoe1
My Ride: 4cyl of fury
Coolant system
VANOS
Transmission fluid
CCV
Oil filter housing
Front CV joints
Valve cover gasket
Brakes
Diff Fluid (Front and Rear)
Transfer case fluid
O2 Sensors
Oil Change History
Power Steering Fluid
Cabin Filter
Engine Air Filter
See above, that's all I can think of for now.
Old 02-11-2013, 12:20 PM   #13
032
My Ride: '03 330xi
The cabin air filter and engine air filter were replaced 5,000 miles ago, and the oil has been changed religiously (every 3-4,000 miles). The brake fluid was also changed.
Old 02-11-2013, 12:22 PM   #14
SamDoe1
Who told you the oil was changed every 3-4k miles? If this is the dealer and they are saying so without records, it is a blatant lie. Very few people change E46 oil every 3-4k miles without being supercharged.
Old 02-11-2013, 12:31 PM   #15
032
My Ride: '03 330xi
The car has a CARFAX report.
Old 02-11-2013, 01:38 PM   #16
SamDoe1
That means absolutely jack sh!t. Unless it came with dated receipts of work performed, I would assume that it hasn't.
Old 02-11-2013, 05:46 PM   #17
032
My Ride: '03 330xi
I assume you don't know what a CARFAX is. When maintenance is performed at either a dealership or a place like jiffy lube, they report exactly what they did, on what date, and at what mileage. Unless you're accusing the people of paying off their car dealership or maintenance company to report false claims to CARFAX.
Old 02-11-2013, 06:08 PM   #18
SamDoe1
I am perfectly aware of what a carfax is and am also perfectly aware that it's often times not right, especially for maintenance done.
So you're telling me that the carfax on this particular car has oil changes every 3-4k miles recorded on it for the past 5+ years? If so, that's impressive and I hope the changes were done at shops that knew what they were doing and not using cheap oil.
FWIW, you don't need to change oil every 3-4k. Every 7500-8k miles is just fine and will save you money.
Old 02-11-2013, 06:11 PM   #19
032
My Ride: '03 330xi
Well, the car is ten years old. The first owner owned the car for about four years and put less than 10,000 miles on it. It might have gone 6 or 7,000 miles without a change once, but it was changed like 10 times in 55,000 miles.
Old 02-11-2013, 09:58 PM   #20
o3BMW325xi
My Ride: 2003 BMW 325xi ZSP
all that stuff on your list is hit or miss, the thing is people on forums OVER blow things. There is people that have those issues at 40k miles and there is others, at least the ones i know with 160k miles and never had to do any of those things beside oil changes...so those issues as i said can be hit or miss in other words...at 55k miles that engine has not even been broken in..so for 9k def go for it. good luck
o3BMW325xi is offline   Reply With Quote
