Go Back   E46Fanatics > Other BMW Models > General BMW E36 Forum
This is the place to get answers, opinions and everything you need related to your E36 (sedan, coupe, convertible and wagon) BMW!
Old 02-10-2013, 12:05 PM   #1
Craig A. Ellefson
My Ride: 325Ci
Head Gasket Repair
Anyone out there in Southern California know of a good place or someone willing to take on a head gasket job and/or engine swap? And about how much it would cost?
Thanks...
Craig A. Ellefson is offline   Reply With Quote
Old 02-13-2013, 02:21 AM   #2
Freddog
My Ride: 08bmw3series 2ltr
Thumbs Up
Thanks...
Depending onhow bad it is ,one way of doing it IS USING A LARGE BOTTLE OF WONDER WELD! TAKE THE TERMOSTAT OUT, FOLLOW THE INSTRUCTIONS, LEAVE IT RUNNING FOR AS LONG AS YOU CAN, EVEN DRIVE AROUND GENTLY FOR A WHILE, YOU ONLY HAVE THE COST OF THE BOTTLE TO LOSE IF STILL LOSING WATER : 2YEAR 'S AGO IFITTED AREPLECMENT ENGINE TOOK ME 9WEEKS TO FIND, HAD IT IN AND RUNNING NICELY I STARTED PICK UP TOOLS&EQUPTMENT WHEN I WENT TO A BLOCK FROM UNDER NEATH CAR ISEEN WATER POURING OUT OF AN EXAUST JOINT THAT IHAD NOT YET TIGHTENT, IWAS TRYING TO CONTACT MY SUPPLYER FOR 3 DAYS! WHEN I PUT WONDERWELD IN ,IT LASTED FOR 25000MILES UNTIL THE WATER PUMP WENT, I HAD BEEN DRIVING IT CONSTENTLY AT 75 MILES PER HOUR WITH FROM A 1/2 TO 1 TON OF A LOAD, SO IT IS WORTH DOING IT : ------ I DID NOT RE DO THE JOB AS I HAD GOT AN ENGINE IN PLACE OF THE FIRST ONE , IT CHEAPER TO FIT IT THEN REPAIR THE OTHER ONE , AS IT JUST COST ME TIME TO DO IT : FRED SEND ME A MESSAGE AS HOW YOU GOT ON :
Freddog is offline   Reply With Quote
Old 02-13-2013, 09:48 AM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Self HG replacement $500-$800.
Shop HG repair $2000-$3500.
Engine swap at shop $3500-$6000.
Of course your cost could vary.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 02-15-2013, 04:27 PM   #4
Freddog
Thanks...
wh r u d' ing wt engine ???????????
