Old 02-16-2013, 07:09 AM   #1
my328cinc
My Ride: 328ci
Unhappy help with engine swap
Hi, well as it says on the title I swapped the engine in my e46 and now can't geted to start. The battery is charged up and making good connection. I just don't understand why the engine rotates slow sounds like tos....tos....tos....tos. I already checked the wiring twice I, I don't known what esle to do. Does someone have any suggestions!"!!!
my328cinc is offline   Reply With Quote
Old 02-16-2013, 07:15 AM   #2
my328cinc
My Ride: 328ci
Old 02-16-2013, 07:34 AM   #3
j_block
My Ride: 2003 325i
What engine did you put in?
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 02-16-2013, 07:36 AM   #4
my328cinc
My Ride: 328ci
2.8l same as last engine
Old 02-16-2013, 07:44 AM   #5
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Has the new engine been checked or tested.before you put it in.
First thing to do is read your engine codes. This will indicate if something is a miss.
Check you 12v to the front +B terminal, and starter. Check your grounds too.
Charge your battery overnight.
Check your fuses and check your e-box fuses.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 02-16-2013, 07:49 AM   #6
my328cinc
My Ride: 328ci
I had a find of my that works mainly with big trucks and 550's put on this big expensive code reader and it was reading all types OK code theft warning, cylinders, ect..........
Sent from my LG-P925 using Bimmer App
Old 02-16-2013, 08:11 AM   #7
BMWCaptain
You will have to systematically check out your car as in my list above to figure it out.
It could be the starter. It could be your new engine compression. Check your oil in the new engine.
BMWCaptainE46.com
