Sponsored by The Tire Rack
Old 02-10-2013, 05:39 PM   #1
s3bas
My Ride: 325ci 02
Do week spacer Really do the trick ?
I was thinking about getting some 20mm spacers but I dont know if they would make that much of a noticible diffrence.
Any suggestions on what else I could do to Get my Wheel farter out.
Sent from my HTC_Amaze_4G using Bimmer App
s3bas is offline   Reply With Quote
Old 02-10-2013, 06:03 PM   #2
JZambrano7
My Ride: 2003 325xi
Put 20 mm on my rears. You be the judge here's a before and after.
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 02-10-2013, 06:09 PM   #3
My Ride: Lexus
Spacing can be good but don't go overboard. 20mm seems alright for a coupe. i have 15mm rear on my sedan but coupes have a wider body (not wider track) so 20mm would probably be fine.
Old 02-10-2013, 06:15 PM   #4
s3bas
My Ride: 325ci 02
Alright yeah they look Good thanks.
Old 02-10-2013, 07:03 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Made a big difference when I put 12mm on my style 44s a while back.
Old 02-10-2013, 10:52 PM   #6
lab rat
My Ride: '02 330iT
25mm was too much for style 44 on a coupe. 20 is perfect.
Because sleeper
Old 02-10-2013, 11:00 PM   #7
patrickmurray2
My Ride: 2005 bmw 330i e46
Is the front stock or did you put a smaller mm in the front?
patrickmurray2 is offline   Reply With Quote
Old 02-10-2013, 11:09 PM   #8
M3JetBlack
My Ride: 2002 M3
I put 20mm in the back and 12mm in front so they match better. Otherwise it looks like the rear is out while the front is tucked. But that is with Style 71...
2002 JetBlack ///M3
CCW Wheels / GC coilovers / Alcon / Eisenmann / SuperSprint / Vorsteiner / HPF Stage 2
Instagram: @somuchcalitis
M3JetBlack is offline   Reply With Quote
Old 02-10-2013, 11:12 PM   #9
JZambrano7
My Ride: 2003 325xi
Front is stock planning on getting 15 mm in the near future
-JZ7-
Old 02-10-2013, 11:29 PM   #10
patrickmurray2
Yeah I have style 68's I belive but will be getting style 135's soon im wanting to do 20mm in the back and at least 10mm in the front I want to keep the wheel from not sticking out at all
Old 02-10-2013, 11:30 PM   #11
patrickmurray2
It looks good im planning on getting some spacers pretty soon
Old 02-10-2013, 11:39 PM   #12
M3JetBlack
My Ride: 2002 M3
So you basically want to make it "flush" with the fender. It will give you a much more aggressive look. Pictures don't do justice!!!
Here is the easiest way to measure the spacer size you need. It's better to get the perfect size the first time. Check out this link http://www.turnermotorsport.com/t-wheel-spacers.aspx
2002 JetBlack ///M3
Old 02-10-2013, 11:52 PM   #13
patrickmurray2
Thanks and yeah pretty flush with the fender if not flush maybe just a tad in, ill check my gap tomorrow though thanks again!
Old 02-11-2013, 12:06 AM   #14
M3JetBlack
My Ride: 2002 M3
Perfect! I got my spacers from Turner Motorsports. I also bought the extended lugs since it was included at a cheaper price.
Mine are pretty flush, but ever so slightly in. Looks pretty good! I am getting some new rims this week so i will most likely be getting new spacers as well.
2002 JetBlack ///M3
Old 02-11-2013, 01:02 PM   #15
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
There definitely will be a noticeable difference!
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
