Sponsored by BimmerWorld
View Poll Results: Clunk Issue...
Solved from Class Action Lawsuit/Subframe Repair 1 5.26%
Solved from differential bushing replacement 2 10.53%
Solved from replacing guibo/CSB 0 0%
Solved from other method, please specifiy! 1 5.26%
Not solved, living with the clunk 15 78.95%
Voters: 19. You may not vote on this poll
Old 02-10-2013, 10:53 PM   #1
Mctwist77
My Ride: '99' BMW 323i
Rear end clunk Poll
Alright so there are hundreds of rear end clunk threads on this site and I thought it would be cool with we got a ballpark figure of how many members have a clunk and how many member had the clunk but go it repaired.
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
Old 02-10-2013, 10:58 PM   #2
Andy2108
My Ride: SpecE46 & E46 M3
What is this poll supposed to be? All of those options could have possibly solved the clunk. And you're overlooking a lot of things... play in the differential, rear shock mounts, broken springs...
Old 02-10-2013, 11:00 PM   #3
Mctwist77
I was just looking to see how people have solved their clunk. Im talking about the clunk people are getting when they are shifting.
Photobucket
BMW 323I 5 Speed
Old 02-10-2013, 11:07 PM   #4
Andy2108
You should specify that more clearly. I think its usually the CSB/Guibo. I'm currently living with it on my M3 but I plan to address it soon. My 330Ci had the same exact clunk.
Old 02-10-2013, 11:10 PM   #5
ryannel2003
My Ride: '04 Cadillac Deville
Sub'd. I have a bad rear diff bushing, csb and guibo. All replacing this week or coming weekend and will report back with results.
ryannel2003 is offline   Reply With Quote
Old 02-10-2013, 11:12 PM   #6
Mctwist77
Awesome! Let us know. Dont be heart broken if it doesnt go away though
Photobucket
BMW 323I 5 Speed
Old 02-10-2013, 11:16 PM   #7
ryannel2003
Eh if not I'm going to live with it. At this point a car with 155k miles isn't worth investing too much more into with things like clunks. My rear diff bushing is actually so bad that pieces of the bushings are missing from the carrier. So I'm about 99.9% sure that's where my problem lies. The diff tool should be here sometime this week and then I'll get started on it.
Old 02-10-2013, 11:21 PM   #8
badfast
My Ride: A car
Solved mine. Replaced the rear diff bushing.
badfast is offline   Reply With Quote
Old 02-10-2013, 11:27 PM   #9
Mctwist77
Tip! Make sure you hit the axle bolts with some pb blaster because if you strip them its not pretty
Photobucket
BMW 323I 5 Speed
Old 02-13-2013, 03:41 AM   #10
J LAU
My Ride: E46 / E82 / E89
I got my rear clunk after around i switched to Coilover around 9 months ago.
i narrowed down to RSM/ diff bushing/ RTAB/ subframe bushings/ other bushings
After reading hundreds of threads/posts. I had my rsm and rtab changed and clunk is still there. So next I am going for my diff bushing.
How much did it cost you guys to get this fixed at the shop.
J LAU is offline   Reply With Quote
Old 02-13-2013, 09:54 AM   #11
Mctwist77
Expect to pay between 300 and 500. You need to drop the diff and use the special tool to put it out and in. If you have jackstands, a jack and you rent to tool off someone on the forums you could save a couple hundred. Dropping the diff sounds scary but its really not.
Photobucket
BMW 323I 5 Speed
Old 02-19-2013, 09:24 AM   #12
J LAU
thanks for the reply. I have been looking up DIYs. Your right, it doesnt sound tooooo bad, but just needs the right tools which is a bitch.
