TCU Programming - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-16-2013, 08:02 AM   #41
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
Originally Posted by TrippinBimmer View Post
Yes and all lights will come on. Don't you have a trans temp gauge.
Nope. Besides this one, what other gauges should I have?
I do have pressure (?) and A/F ratio.
Jim
Jim Murphy is offline   Reply With Quote
Old 04-16-2013, 10:09 AM   #42
WALKD U
My Ride: Just Fast!
Jim
Jim,
I would recommend an trans temp gauge. I bet u was getting a tran tq overheating code...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 04-17-2013, 03:30 PM   #43
Jim Murphy
Just had it looked at by Jason at BIP - the code is about bad communication
between the main computer and ABS and TC. While he was checking this out
he found that the battery was starting to die - too low a voltage reading. I went and replaced it immediately. I will keep driving it to see what happens.
In the meantime, I am starting to burn/consume oil much too quickly . . . .
Jim
Old 04-17-2013, 08:10 PM   #44
WALKD U
My Ride: Just Fast!
Which oil? Tranny? Engine? or S/C?
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 04-18-2013, 09:52 AM   #45
Jim Murphy
Engine . . . . .
Old 04-18-2013, 02:06 PM   #46
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
Jim I was having the same trouble once I started running my supercharger last semester. I was told by my mechanic that I'm just going to have that auto trans limp problem as long as im sending that much power through that transmission. But this point about tire differences is interesting. I run square tires and wheels though my rear is 40mm wider with spacers. Maybe I'll try losing the spacers to see if that does the trick?
drumbum624 is online now   Reply With Quote
Old 04-18-2013, 02:36 PM   #47
WALKD U
My Ride: Just Fast!
Any Tranny Mods? Spacers wont affect the Tire Size Rotation.
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 04-18-2013, 02:59 PM   #48
drumbum624
My Ride: 325xi
No tranny mods. just 10.5 psi. and to clarify it is an xi, which people have frowned upon using spacers with. any other reasons I would have this same tranny light issue?
Old 04-18-2013, 03:08 PM   #49
WALKD U
My Ride: Just Fast!
No mods = Tranny overheating due to slippage. Once Tranny Slip so much it will throw a light.
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 04-19-2013, 03:15 AM   #50
Mormon
My Ride: 2001 330xi
If he were to put in a ipt valve body, would that fix the problem?
Mormon is offline   Reply With Quote
Old 04-19-2013, 01:48 PM   #51
Jim Murphy
First, bring the transmission oil temperature down with an external oil cooler - I have one but you will still need to completely upgrade your transmission with IPT ($5K+) like I did, the torque converter, valvebody and the transmission parts like the clutch disks. With a 4 wheel drive the transmission is taking a real beating especially if you are FI as well. On second thought, go to the biggest oil cooler that you can fit due to previous sentence - and a oil temperature gauge, too.
Jim
ps - who makes the best gauge and where do you buy it and install it?
Old 04-24-2013, 09:50 PM   #52
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I'm a big fan of fully programable dashes that allow you to datalog.
Cheapest:Aim MXL
Best value: Motec CDL
I understand that you're talking about a couple of hundred $$, and I'm talking a couple of thousand $$...but once you step into the big HP game...you kind of need better tools than a gauge to troubleshoot issues with.
For the transmission, I would be interested in:
Input shaft speed
Output shaft speed
Internal oil temp
Oil return temp from cooler
Engine RPM
TPS
Shift-up signal
Shift-down signal
That's what I'd be logging to start with...
Old 08-23-2013, 04:43 PM   #53
Jim Murphy
It has been awhile since I last updated this thread. We went full circle and tried some 255/35's on the rear and, surprise!, the traction control trouble light no longer comes on or puts me into Semi Limp mode. Now I am running 255/35's all the way around on 8.5's with no TC trouble.
When that got fixed other areas started going bad:
1. Electric aux fan motor burned up and got replaced but it blew the connection to the DME causing IT to go bad = install used DME with good fan connection and re-program it.
2. Alternator burned up on me leaving me dead in the water, stranded in traffic = new alternator
3. Two belt tensioners are worn out (could not get boost above 5 lbs) and while replacing them, the P/S pump shaft is found to have excessive wear (floats in and out a lot) so it gets replaced as well with an upgraded pump requiring new hose connectors.
4. And finally spark plugs replaced.
All this and the odometer just hit 66K, BUT the car is running again like it should for the first time in a LONG while.
But my Visa is now maxed out from all these repairs, sigh . . . . .
Jim
Back to autoxing the Jeep and helping F600's in their money race series.
