Sponsored by The Tire Rack
Old 02-11-2013, 06:03 PM   #1
EliteE46M
My Ride: 2004 BMW M3
Wheel spacers
Hey guys i have an 04 330ci M sport with style 135 rims. I am thinking of buying a set of thin spacers for the rear only. I was thinking 15mm since i dont want any rubbing or anything. Now my question is, will those fit? is 72.5mm the hub size that i should look for? http://www.ebay.com/itm/5x120-72-5-1...2d72f3&vxp=mtr if no can anyone recommend me a set that will fit? Anything else i need to know before i run spacers?
thanks
EliteE46M is offline   Reply With Quote
Old 02-11-2013, 06:07 PM   #2
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
You need longer wheel bolts. And I would recommend buying real ones used rather than eBay ones. It might seem like a simple piece to make but I wouldn't trust a random no name part when it's that vital to safety. The tolerances could be way off or the metal could be sub par.
Old 02-11-2013, 06:54 PM   #3
s3bas
My Ride: 325ci 02
Would a 20 mm spacers work with a 2002 325 ci with out cousing problems if not what is the biggest I could go. On rhe rear
Sent from my HTC_Amaze_4G using Bimmer App
s3bas is offline   Reply With Quote
Old 02-11-2013, 07:52 PM   #4
fiveightandten
My Ride: '03 330ci / '98 M3
15mm isn't a thin spacer. Thin is like 3mm or 5mm. I don't have style 135's, so I can't comment on clearance. But as stated above, you will need either extended bolts or a stud kit. But please don't buy used bolts. That's dangerous, as you don't know if they've ever been over-torqued or not.
-Nick
fiveightandten is offline   Reply With Quote
Old 02-11-2013, 11:02 PM   #5
s3bas
My Ride: 325ci 02
Alright thanks for the help
Old 02-12-2013, 06:01 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Measure your clearances and go from there.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-12-2013, 06:47 PM   #7
s3bas
My Ride: 325ci 02
Thanks Man what if my tires clear all the way trough what the biggest spacers I should Get without comprimising anything.
Old 02-13-2013, 02:50 PM   #8
VMRWheels
VMRWheels's Avatar
The best, most precise method, is to measure. We can guess but your car may be different than other people's cars, so their recommendations might not work in your case.
