Old 02-11-2013, 09:43 PM   #1
rudycoop
My Ride: 3 pedal 330i
Has anyone ever mixed 2 stroke in their gas?
There is a forum w 51 pages of responses talking about using 2 stroke in your fuel tank. Mixing 1 ounce of 2 stroke per 5 gallons of gas. It supposedly does a whole lot of good.
lubricates the fuel pump/seals/injectors.
cleans the fuel system and scavenge water that ethanol attracts.
Creates a film of protection in our fuel system to stop corrosion.
Acts as a cleaner for our spark plugs/valves/combustion chambers.
Cleans the ring packs
Leaves a film on the cylinder walls to eliminate cold start metal wear.
Afterwards you will be
A) Run Smoother B) Run more efficiently C) Parts will last longer i.e. fuel pumps/injectors etc. D) Should see more RWHP and MPG
For pennies!
I used this on numerous vehicles and have recently been doing it on my 325i. Every fill up I measure it out and dump it right in with the gas.
Curious is anyone else has done this?
rudycoop is offline   Reply With Quote
Old 02-11-2013, 09:45 PM   #2
wildirish317
My Ride: 2004 325Ci vert
Not me.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-11-2013, 09:45 PM   #3
tmr931
My Ride: 330ci
makes sense
tmr931 is offline   Reply With Quote
Old 02-11-2013, 09:50 PM   #4
TurnersInOz
My Ride: 2004 325i
Nope, never done that.
Can't see how a lot of those points would be valid, given that all you are doing essentially is putting oil in the gas.
For example I cannot see how adding oil to the fuel would do anything for water in the tank. The two don't mix. Oil+anything generally does not equal clean.
I'd also be curious to see what effect, if any, this could have on sensors and cats.
TurnersInOz is offline   Reply With Quote
Old 02-11-2013, 09:53 PM   #5
wildirish317
For pennies!
Okay, in before WDE46 and DonaldE, among other engineers. A few questions:
I used to use gasoline to clean up oil residue, not the opposite. Since when does oil absorb water?
Isn't that what motor oil is for?
Old 02-11-2013, 09:54 PM   #6
jgold47
My Ride: 2004 X5 3.0
most e46 owners already do this. Its called burning oil.
I mix a little milk in with my gas. Usually skim, but sometimes 2%. I figure it does a body good. I've never had a car rust on me and I live in Michigan.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 02-11-2013, 09:57 PM   #7
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
putting oil in the gas...? seems like it would just make combustion weird and unpredictable.
it would also foul the plugs.
and it will screw your cats
Old 02-11-2013, 09:57 PM   #8
wildirish317
And I forgot to include the statement that caused me to respond in the first place. Does 2 cycle oil have a higher btu/lb content than gasoline? If that's the case, why don't we run our engines on it to begin with? How much btu does it add to a tank of gas? How much does it cost per gallon?
Old 02-11-2013, 10:03 PM   #9
always-there
My Ride: 2002 BMW 330I
And while you're at it op, make sure to replace your muffler with that of a lawnmowers; they're said to have a more free-flowing muffler.
Old 02-11-2013, 10:06 PM   #10
NJFF26
My Ride: 02 325xi
I will put what I have left from a day of riding my dirtbike in my van it doesn't hurt it but I wouldn't waste money on it on my car
NJFF26 is offline   Reply With Quote
Old 02-11-2013, 10:12 PM   #11
Brevik
My Ride: Tiag M3
I also suggest installing a 48 inch John Deere deck to save wear on your lawn mower while you are at it.
Brevik is offline   Reply With Quote
Old 02-11-2013, 10:15 PM   #12
peytonracer4
:D
My Ride: '00 328i
Old 02-11-2013, 10:23 PM   #13
HacksawMark
HacksawMark's Avatar
My Ride: 2014 Subaru XV
For pennies!
HacksawMark is offline   Reply With Quote
Old 02-11-2013, 10:31 PM   #14
///MPR77
My Ride: 02 ///M3 Tri-Ped
When I was two years old, my parents bought me a Suzuki jr50 w/custom fab training wheels
It was 2 stroke.
Old 02-11-2013, 10:37 PM   #15
metalmania305
My Ride: 2000 323i
What do we have, scooter motors? I remember a scooter I had that I had to mix 2cycle oil with the gas to make it work, but not on my bimmer you crazy.
metalmania305 is offline   Reply With Quote
Old 02-11-2013, 10:39 PM   #16
B_Cyrus
Banned User
My Ride: Malfouf
This isn't an RX7, and E46's already burn oil.
B_Cyrus is offline   Reply With Quote
Old 02-11-2013, 11:57 PM   #17
rudycoop
It has been extensively tested on other forums and I will say it again, 51 pages of positive results. I have been doing it and my 325 runs and idles like new.
Check it out:
http://www.ls1.com/forums/f48/been-testing-91206/
Old 02-12-2013, 12:06 AM   #18
rudycoop
Here is another good link:
http://www.bobistheoilguy.com/forums...107478&page=21
Old 02-12-2013, 12:24 AM   #19
lcoleman
My Ride: '79 Massey Ferguson
Originally Posted by B_Cyrus View Post
This isn't an RX7
Shucks, came in here to say that. Sounds like a silly idea.
Old 02-12-2013, 01:05 AM   #20
Andy2108
My Ride: SpecE46 & E46 M3
what has this place come to
