Sponsored by BimmerWorld
Old 02-12-2013, 09:36 PM   #1
s3bas
My Ride: 325ci 02
Would barake caliper cocer for a 330 ci fit on a 325 ci ?
Sent from my HTC_Amaze_4G using Bimmer App
s3bas is offline   Reply With Quote
Old 02-12-2013, 09:46 PM   #2
Cablekid
Account Under Review
My Ride: E46
No,
Please USE
330i CALIPER AND ROTORS + BRAKES.
Then they will work fine.
Cablekid is offline   Reply With Quote
Old 02-12-2013, 10:01 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
...maybe...might be the larger caliper won't fit with the wheels you have.
Personally, I think you should just use the calipers made for your car. Was there an issue with your calipers? If not, with the right pads (textar) they should stop you just fine. Remember that the different sizes on front and rear are to control brake 'bias.' Most stopping happens in the front, but some happens in the rear. I wouldn't substantially change the ratio of stopping power from front to rear...mostly because I'd be concerned about stability in emergency situations. I'm old and fussy and like my things properly taken care of. No reason to change your caliper sizes, unless you're racing, and if you are, you probably know enough to search for the answer to your question.
Be careful anytime you go 'off stock.' Make sure you've thought of the variables. In your case, having the calipers/rotors fit inside the wheel you have. Be careful...and good luck.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 02-12-2013, 10:08 PM   #4
Cablekid
My Ride: E46
THEY WILL FIT.
But you need Calipers + Rotors+ Pads from a 330i
They are Bigger, better for braking.
Old 02-12-2013, 10:19 PM   #5
WDE46
My Ride: '13 128i, '04 330Ci
I'm pretty confident you both misunderstood the OP. Allow me to translate (I'm fluent in retard):
Would a brake caliper cover for a 330Ci fit a 325Ci
No. s3bas, the 330 brakes are larger than the 325 brakes. But allow me to translate just in case:
nop sjaeja the 330 bjakwak are lrlgrer thne the 325 brakkes.
Off topic: Is your name pronounced "sea bass"? If so, is that a reference to Dumb and Dumber?
Old 02-12-2013, 10:20 PM   #6
choxor
My Ride: JDM
Chill out with the bold font. It's like you're screaming.
Pretty sure you'll need the carrier as well?
Old 02-12-2013, 10:25 PM   #7
Cablekid
My Ride: E46
I am screaming.
Yes you need carrier as well.
Old 02-12-2013, 10:28 PM   #8
WDE46
Did you guys ignore what I said? He is asking about caliper COVERS. This is an aftermarket item.
The "C" is next to "V" on the keyboard. Unless you don't QWERTY.
Old 02-12-2013, 10:37 PM   #9
s3bas
My Ride: 325ci 02
Yeah that was my fault its my freaking spellckeck on my phone .
How much migh they cost ?
Old 02-12-2013, 10:39 PM   #10
WDE46
The first ones that pop up on google are MGP covers that go for over $150. These are going to make your rotors look undersized after you put them on just FYI.
Old 02-12-2013, 10:46 PM   #11
s3bas
My Ride: 325ci 02
Thanks for the help I look into it.
Old 02-12-2013, 10:47 PM   #12
325inthe510
My Ride: 152ci of madness
Your spellcheck is terrible, I suggest you get an Iphone
325inthe510 is offline   Reply With Quote
Old 02-13-2013, 12:40 AM   #13
briangl92
My Ride: VQ37VHR
The iFone spell cheek is much bedder compared too that of Androids.
Sent from my iPhone 4S using Bimmer App
briangl92 is offline   Reply With Quote
Old 02-13-2013, 12:42 AM   #14
Zell
Zell's Avatar
My Ride: so turbo wow
My Windowz phone spell check is pretty good once you use it for a little bit. It seems to learn how I type and suggests the next word for me based on the sentence structure so I can type with one hand really easily. Fairly cool.
Old 02-13-2013, 01:00 AM   #15
fiveightandten
My Ride: '03 330ci / '98 M3
Spell check is no excuse for hitting the post button without reading things to make sure people can understand you. God, this forum keeps getting worse.
-Nick
fiveightandten is offline   Reply With Quote
Old 02-13-2013, 01:05 AM   #16
Zell
Zell's Avatar
Just wait 'til 10 years from now when these cars are really affordable.
Here's a sneak peak:
http://forums.maxima.org/4th-generat...a-1995-1999-6/
Old 02-13-2013, 01:10 AM   #17
fiveightandten
Luckily we won't have to worry about that, as all the E46's that are on the road now will have had their floor pans ripped apart by then, and will have been melted down and recycled into new 3-series with 7th generation iDrive, power electric everything, and no dipsticks.
-Nick
Old 02-22-2013, 03:16 PM   #18
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Mine won't rust I live in AZ so I'm safe lol
325CiMaN is offline   Reply With Quote
