Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 02-12-2013, 09:50 PM   #1
sandman512
My Ride: 2005 325I
Looking to do an Outdoor Fireplace.
Looking to put an outdoor fireplace in my back yard. The dilemma I have is that it is going to be off my wood deck(cedar finished). Is this similar to having a fireplace in my den with an oak floor? Same concept? Has anyone ever done an outdoor fireplace? Pics? Any thoughts? Thanks!
sandman512 is offline   Reply With Quote
Old 02-13-2013, 07:04 AM   #2
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Do not put a fire pit on your deck
JonJon is offline   Reply With Quote
Old 02-13-2013, 12:03 PM   #3
SamDoe1
My Ride: 4cyl of fury
^ This.
The fireplace you have indoors is a very controlled burn environment, or at least it should be. Unless you are willing to go through the same design work to assure a controlled burn on your deck, I would just dig a hole in the ground and call it good.
Wait, re-read your post. You want to build an outdoor fireplace off your deck? If so then there are numerous kits and pictures online of how to do this. It's really not difficult. Depending on how elaborate you want it to be, it could be as simple as building a firebox out of brick and fire brick (don't use regular brick on surfaces exposed to high temp and/or open flames) or as elaborate as adding a wood frame covered with whatever you want (brick, stone, etc) to make something with a countertop, grill, whatever on it.
Old 02-13-2013, 02:53 PM   #4
sandman512
My Ride: 2005 325I
JJ, not a firepit on the deck, a fireplace off the deck.
Originally Posted by SamDoe1 View Post
^ This.
Yes, looking to put a fireplace off the deck. There are several kits out there to do this. Ideally, I'm looking at a Cambridge kit. If you have any suggestions, link, feel free. Thanks!
Old 02-13-2013, 03:19 PM   #5
SamDoe1
Link to your kit?
My suggestion would be to not use a ready built kit but to design your own. Stacking bricks isn't hard to do and you can make something that's truly your own that way.
Old 02-13-2013, 03:49 PM   #6
sandman512
My Ride: 2005 325I
http://www.cambridgepavers.com/cfile...wFireplace.cfm
Old 02-13-2013, 05:06 PM   #7
brew
My Ride: F150 X5 MR2
5 minutes of carrying rocks over and arranging them in a circle:
brew is offline   Reply With Quote
Old 02-13-2013, 05:08 PM   #8
sandman512
My Ride: 2005 325I
Fireplace, not pit.
Old 02-18-2013, 10:13 AM   #9
Maniac
My Ride: platinum ecoboost R6
We install outdoor fireplaces all the time - talk to the homeowners a year later they don't get used often and te framing / rock work blocks a side of your deck - I'm not a fan that said we usually install Napoleon GS series
<img src=http://i194.photobucket.com/albums/z76/E46Maniac/signumber2.jpg border=0 alt= />
Originally Posted by 46_coupe View Post
Attractive and stable works for me...I'd rather help wifey program the stove clock than wonder if she purposely left the gas on :eek:
grey green metallic-gone
platinum ecoboost on 35 toyo MTs
Maniac is offline   Reply With Quote
Old 02-18-2013, 10:31 AM   #10
sandman512
My Ride: 2005 325I
Maniac,
Any pics installed off a deck. I'm just worried about it being in close proximity to a wood deck, but I guess its the same idea as in a den near an oak floor?
Thanks!
