Facelift Coupe Ballast Wiring Problem Please Help! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-13-2013, 08:01 AM   #1
05swtc
My Ride: 330ci
Problems after UpgradeHelp!!.. I have a 2005 facelift coupe with adaptive bixenon projectors. The problem started with a failed ballast in the right headlight. Rather than replace the ballast with oem, I elected to retrofit with a set of Morimoto ballasts from TRS. Prior to the installation of the new ballasts, my left headlight functioned normally even though the right was out. Yesterday I installed the Morimoto ballasts by tapping into the pigtail with the grey connector to the back of the headlight. I started with the right light as it was the one that was out and after making the connections, I tested the lights..Taa Daa!! The right headlight fired and worked perfectly, however the left would not fire. I figured it was a fluke so I installed the left exactly the same as the right and the left still would not fire with the new ballast. I checked the grey pigtail for voltage and no power is being supplied to this connector. Mind you it worked perfectly before I started on the right side but I canít figure why the left went south when I installed the right.. Any insight would be greatly appreciated.
Thanks in advance!!
05swtc is offline   Reply With Quote
Old 02-13-2013, 04:36 PM   #2
05swtc
My Ride: 330ci
Update...seem to have solved the ballast problem but can anyone confirm that the active headlight circuit is related to the ignitors in any way
Thanks again
