Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 02-13-2013, 10:42 AM   #1
Zyzz
My Ride: 1 series hatchback
'08 1 series hatchback jerky movements
Hello good people!
I noticed a jerkyness in my car the last few days. It started about 5 days ago as I was starting my car at about -17 degrees celcius. It took about 3 seconds for the car to start fully, as it was very cold. Then I noticed that the engine lamp was yellow. This light turned off about 1 minute later. When I drove off the driveway, I noticed that the car had some jerky movements. This specially happend, and still happens at 1500 RPM at 3rd gear, but not only. Btw; the car is automatic, with the option of using "manual" selection. I notice that when I turn this manual function on, and shift up myself, the car accelerates more smoothly, even tho the problem is still noticeable sometimes. I do not feel any jerkyness at higher speeds like 60-80 km/h. Is this something serious, should I take it to a mechanic asap? I have about 0 knowledge about cars and engines, so I have no clue whats going on. Found this thread: http://forum.e46fanatics.com/showthread.php?t=957618 with about the same problems. Could it be something with my transmission oil?
Help much appreciated. Thanks in advance!
Drive safe!
Edit: Found this video that exactly describes my problem:
Zyzz is offline   Reply With Quote
