Old 02-14-2013, 12:55 PM   #21
cyberkaa
My Ride: E46 332i,M3;E30 325i
Originally Posted by shanneba View Post
The engine too quiet codes makes me think even more about a thorough check of the knock sensors and electrical connection is in order.
Hopefully the car has at least 91 octane fuel, the default maps in the ECU are set for that octane.
Agreed.
-Kalim
(klx photo studio)
Old 02-14-2013, 01:48 PM   #22
thekrauthouse
My Ride: 2000 740, 2002 325
There is a Country Mart at Crane out past Westgate in Scottland if you want to run out there and try it. I've always gotten good gas at Hassler's Junction.
thekrauthouse is offline   Reply With Quote
Old 02-14-2013, 02:04 PM   #23
jfoj
My Ride: 330CiC, M5, X5, E93
Just tossing something out, does not happen often and usually quiets or gets slight louder under load.
Auto trans flex plate cracked???
Might change when put into gear and the neutral or brake torquing engine.
Recording would be helpful.
Old 02-14-2013, 04:16 PM   #24
Jakall
My Ride: 2003 325Ci
Ok, I come bearing video. The audio didn't come out as clearly as I would have liked, so I'll try to provide better videos later today.
Engine at idle: the tapping is softly audible around 0:15-0:20
Tapping while driving: the tapping is audible when driving past the garage doors (0:05-0:09 and 0:12-0:14) . A curb or wall is needed to bounce the sound back.
Jakall is offline   Reply With Quote
Old 02-14-2013, 04:33 PM   #25
lcoleman
My Ride: '79 Massey Ferguson
Definitely sounds like some kind of valve noise to me. And it doesn't seem that bad at all, at least in video. Be glad you don't drive an e30, the m20 sounds like a sewing machine.
Old 02-14-2013, 05:23 PM   #26
Jakall
My Ride: 2003 325Ci
"Sewing machine" is a great way to describe the sound. Here's another video where it can be heard more clearly.
Old 02-14-2013, 06:41 PM   #27
330iPilot
My Ride: Titanium Silver 330i
Sounds to me like wrist pin slap. But you've already ruled that out so I have no idea.
330iPilot is offline   Reply With Quote
Old 02-14-2013, 07:19 PM   #28
wildirish317
My Ride: 2004 325Ci vert
After hearing it, and wading through a few hundred posts about tapping noise, the only thing that hasn't been mentioned here that you might check are the injectors. The fact that it goes away when you let of the gas (injectors stop?) might point in that direction. Keep us posted. We love puzzles.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 02-15-2013, 12:20 PM   #29
Kubica
My Ride: 2003 325xi
Originally Posted by Kubica View Post
I would guess it's a lifter or injector making the tapping noise.
Oh no?
Old 02-15-2013, 12:23 PM   #30
wildirish317
Oh no?
I swear, I read every post! Sorry.
Old 02-15-2013, 02:04 PM   #31
330iPilot
Well you didn't you big dummy! Pay attention dammit!
Old 02-15-2013, 02:07 PM   #32
wildirish317
lol. Payback is a bitch.
Old 02-17-2013, 12:48 PM   #33
Hellzbellz
My Ride: 316ti compact sport
Hey, I have a ticking rattle noise from my e46 316ti, not sure if same but it sounds like you have pretty much replaced most of the engine!! I've had timing chain, guides and tensioners replaced and timing reset. As advised by BMW stealers. Still same noise!! Starts fine first time all the time noise only after started 2mins and more evident at 18000-2000 revs, drives fine no apparent loss of power. Ive located the noise to the area where stepper motor/VVt Motor
Having listened to the noise in this video heard on you tube:
I am beginning to think its noise resonating from Vacum pump, see comments below video.
Real oem part: http://www.realoem.com/bmw/showparts...78&hg=11&fg=15 Part is No:2 here
Let me know if you ever did find out what was causing the noise as I need help too!!
Hellzbellz is offline   Reply With Quote
Old 02-17-2013, 12:51 PM   #34
Hellzbellz
Sorry last post wiped my link to stepper/VVT motor Real Oem : http://www.realoem.com/bmw/showparts...96&hg=11&fg=15
Part No:9 here - concerned about the PUMA reference - you know about PUMA - its where the dealers cant figure out whats wrong and have to go back and seek help from those in the know back in germany!!
Old 03-23-2013, 12:51 AM   #35
Mazbo1
My Ride: 2002 BMW 330i
Flex plate for real! Im on my second flex plate... the original broke and made that horrible tapping noise... then last week the used one I bought started making noise... time to get a new one ....
Mazbo1 is offline   Reply With Quote
Old 03-23-2013, 02:20 AM   #36
REKLESS ROB
My Ride: 2004 325ci
^ check the flex plate.
Also, have you checked for any exhaust leaks, especially around the manifold. Possible warped flange? Cracked manifold?
REKLESS ROB is offline   Reply With Quote
Old 03-29-2013, 07:25 PM   #37
REKLESS ROB
My Ride: 2004 325ci
Op, any new news? Just curious.
Old 03-29-2013, 07:30 PM   #38
Jakall
My Ride: 2003 325Ci
The flex plate is something none of us had thought of, and I plan to bring it in for diagnostic early this coming week. I'll definitely post a follow-up... thanks for the recommendation!
Old 04-18-2013, 11:04 AM   #39
Jakall
My Ride: 2003 325Ci
My mechanic got under the car to take a look at the flex plate (is there an inspection port or something for that?) and said it looked fine. I'm now also losing about a quart of oil every two weeks (it isn't dripping), which happened pretty suddenly. At this point I'm about ready to say screw it, swap in a warrantied longblock, and hope for the best. Is Bavarian Auto Recycling the right way to go, or do you guys have a better recommendation? Is it worth shelling out extra for an upgraded warranty?
In other news, the car is also now making an irregular ticking (separate from the tap discussed in the rest of the thread) under hard acceleration, such as when accelerating onto a highway. It happens around 3-4k RPM (tick, TICK TICK, tickticktick) and goes away as soon as the automatic transmission changes gears, so I can't tell if it's a load-related issue (one of the joints going bad?) or the start of a transmission issue.
Here's a video... it's hard to hear, but starts at about 0:03
Thanks for the solid advice so far, guys!
Old 04-18-2013, 11:36 AM   #40
Kubica
My Ride: 2003 325xi
I would try a slightly thicker oil and overfill it slightly before junking the motor.
e46 tapping, engine noise, tapping, ticking
