E46 Xi Forum
Old 02-13-2013, 09:40 PM   #1
Sabreman
My Ride: '04 330xi auto
2004 330xi oil capacity??
I remain confused. My owners manual says 6.6 qts on oil/filter change for xi. The service manual says 8.0 for all wheel drive (6.9 otherwise). Per prior threads some possibility pre-facelifts used 8 and later years (mine is 04) take only 6.6. Dipstick seems full with 6.6. Dealer charges for 8 but dipstick shows overfill. Is there some definitive answer out there????
Sabreman is offline   Reply With Quote
Old 02-13-2013, 10:06 PM   #2
bmwporschefan
My Ride: 2001 330xi
I know mine uses 8. I had no idea that later years used less.
'01 330xi
bmwporschefan is offline   Reply With Quote
Old 02-13-2013, 10:10 PM   #3
e46alfonso
My Ride: 330xi MT, mustang gt
8 is too much. I'm at the top of the dipstic with 7 quarts.
Old 02-13-2013, 11:19 PM   #4
bmwporschefan
My Ride: 2001 330xi
Owners manual says 8, repair manual says 8, if I only add 7 quarts my dipstick shows I am a quart low. So the verdict is my car holds 8 quarts.
'01 330xi
Old 02-14-2013, 12:06 AM   #5
e46alfonso
You are right, earlier xi's have a different oil pan and hold more oil.
Old 02-14-2013, 12:15 AM   #6
limpiabota809
My Ride: 330 XI
My 03 was at max with 7
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 02-14-2013, 10:11 AM   #7
SamDoe1
My Ride: 4cyl of fury
My 2004 is at max with 7ish.
Old 02-14-2013, 11:37 AM   #8
chilone
My Ride: 04 330xi, 97 Miata
What he said...
chilone is offline   Reply With Quote
Old 02-14-2013, 04:02 PM   #9
GCoop
My Ride: '04 325xi
Oil capacities in the XI are a much debated topic. For some reason it seems that some XIs hold almost 8qts while others (Myself included in this bunch) only take ~7 to reach the full mark.
The reasons for this run the gambit-- From 2 different oil pan shapes (see below) used on the XIs to the updated dipsticks that register full @ ~7qts. There has been no definitive answer as to why from what I have been able to research. I have also seen printouts from owners manuals with different figures. Generaly speaking it "seems" that the higher capacity figures are mostly from earlier production XIs but not always. Clear as mud yet?
Same as what I have (7 Qt pan):
Here is the other:
GCoop is offline   Reply With Quote
Old 02-14-2013, 07:57 PM   #10
My325XI
My Ride: 03 325XI Sprt Prem
I use 7 qt's
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 02-14-2013, 08:09 PM   #11
caleb6
My Ride: 2005 330XI
According to Bentley, its 7.9 qts. (7.5 liters) Page 119-1.
caleb6 is offline   Reply With Quote
Old 02-14-2013, 08:57 PM   #12
White_Knuckles
My Ride: 2003 325xi
GCoop has the win. They vary.
It's easy, put in 7 qts. and pull the stick. Add as needed.
Mine holds 7.5 qts. every change even with extended drain times.
Old 02-14-2013, 08:57 PM   #13
bmwporschefan
My Ride: 2001 330xi
Originally Posted by GCoop View Post
Here is the other:
This is the pan I have.
'01 330xi
Old 02-15-2013, 08:53 AM   #14
jonnie325xi
My Ride: 2004 325 XI
I have a 04 325 XI and 6.6 puts it right at the proper level of the dipstick.
jonnie325xi is offline   Reply With Quote
Old 02-17-2013, 02:56 PM   #15
Sabreman
Thanks for all the replies. For my car 2004xi, I'm going to stay with 6.6 per owners manual and my dipstick and not worry that the xi spec per service manual seems to list 8 qts but makes no distinctions among years.
Old 02-17-2013, 03:41 PM   #16
bmwporschefan
My Ride: 2001 330xi
That's what I would do man. Go by your dipstick. I wasn't even aware they changed the oil pan design sometime after mine was built.
'01 330xi
Old 02-19-2013, 11:13 PM   #17
SilvaBimma
My Ride: 330Xi
7 Qts, 2001. Always had the illusion it took more but measured when I did an oil change. These engines do drink some oil after awhile.
SilvaBimma is offline   Reply With Quote
Old 02-20-2013, 05:55 PM   #18
latitude39
My Ride: 2002 325xi (163k)
325xi 2002 (11/2001 build)
7 quarts gets me to the high limit on dipstick
During 7,500 mile service I add .6 - .7 quart
140k
latitude39 is offline   Reply With Quote
Old 06-26-2013, 09:06 PM   #19
shadow 2
My Ride: 07 328i
What is this statement about change of dipstick? When did this happen? How do I know the dipstick I have is the correct match for the oil pan?
shadow 2 is offline   Reply With Quote
Old 06-27-2013, 10:25 PM   #20
jmo69
My Ride: 03 325xi 98 328is
My 03 325xi takes 7qts.
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
