E46 Convertible
Old 02-13-2013, 10:54 PM   #1
Lips030190
My Ride: 330cic convertible
Question E46 Convertible Bluetooth
Does any have a recommended Bluetooth for my bimmer that integrates well?
Lips030190 is offline   Reply With Quote
Old 02-13-2013, 11:02 PM   #2
johnrando
My Ride: '06 330 CIC ZHP
I use Parrot for BT and Connects2 for integration into the steering wheel controls. Works just fine. I believe Parrot now has their own integration kit. Just check parrot.com. There are other options too.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 02-14-2013, 07:49 PM   #3
Redflea
My Ride: 2005 330Ci/2003 530i
Parrot is high quality stuff, ran it in my old e34 for quite a while w/no issues.
I believe you can also get a BMW BT module and add it to your car...I believe it mounts in the trunk on the left side.
Redflea is offline   Reply With Quote
Old 02-15-2013, 08:27 AM   #4
e46mook
My Ride: 2004 330cic
I got the newer model TCU for my car and it works great. Unlike the coupes/sedans which most of the install DIYs are from, the module is not on the left side of the trunk, but to the left of the ski pass in the trunk.
Remus - Dinan - H&R - AC Schnitzer
e46mook is offline   Reply With Quote
Old 02-15-2013, 10:41 AM   #5
Redflea
Thanks...did you find a DIY specific to our verts, or did you take any pics while you had things apart?
I did run into this...echoes your comment that the module is the rear of the trunk, rather than on the left side as w/the sedans.
http://www.bimmernav.com/e46cab.html
Old 02-18-2013, 05:05 PM   #6
bchickness
My Ride: 2000 323i conv
Go To Crutchfield.com,they Have Lots Of Options and Service What They Sell With Great Tech Support.
bchickness is offline   Reply With Quote
Old 02-19-2013, 08:58 AM   #7
mxracer707
My Ride: 2006 BMW 325ci
I have had good luck with Parrot as well, although the install was a PITA. There were a few electronic boxes that I needed to squeeze behind the headunit in my old A4.. and instructions were pretty weak.
mxracer707 is offline   Reply With Quote
Old 02-19-2013, 02:30 PM   #8
ragtop69
My Ride: 2004 bmw 330 conv.
I have an 04 conv and upgraded to the newer tcu as well. Just removed the old one and replaced with the new one it was a couple of bolts and electrical connectors. You also need the antenna and ant mounting bracket that goes under the center console. The system works great for me
ragtop69 is offline   Reply With Quote
Old 02-19-2013, 03:26 PM   #9
Lips030190
Did you have Sirius sat radio in your '04?
Old 02-19-2013, 04:10 PM   #10
e46mook
I followed a coupe diy and then just started ripping apart the trunk. The diy you linked is right on, except if you are installing a TCU, then you do not have to worry about the pairing button in step 3.
Old 02-19-2013, 11:35 PM   #11
ragtop69
I just had the business radio
