///M3 Forum
Old 02-14-2013, 01:31 PM   #1
SHe46M3
My Ride: e46 m3
Lowering with springs
Just got some csl wheels last month and just wanted to know is it that bad to go with springs lower your an inch instead of buying a whole suspenion
SHe46M3 is offline   Reply With Quote
Old 02-14-2013, 01:57 PM   #2
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
It's not as ideal as doing a "kit" as the damper is designed to have a certain amount of travel - by adding a shorter spring, the damper is being compressed more than it would with a standard spring so you damper will now have less travel than before. Not detrimental by any means, just may wear them out a little quicker and not have as nice of a ride.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 02-15-2013, 12:13 AM   #3
illestminimike
My Ride: Project Drama
Have you looked into coilovers?
Old 02-15-2013, 03:07 PM   #4
SHe46M3
My Ride: e46 m3
Been looking into coil overs and someone told me that kind of messes with the handling of the car I just basically want to lower my car and keep the handling good as it is with out spending over 3k for a new suspenion
Old 02-15-2013, 03:10 PM   #5
scca_ziptie
Coilovers (unless a cheap brand) will not mess with the handling of the car, if anything they improve/accentuate the handling of the car. Is your car going to be a pure daily driver (normal/spirited drives) or will it see the occasional track day/autoX ?
Old 02-15-2013, 10:52 PM   #6
SHe46M3
My Ride: e46 m3
Daily drivers never launch it but I do rip it sometimes
Old 02-15-2013, 10:59 PM   #7
nojoda
My Ride: 06 M3Vert 6MT JB/CIN
if you do springs, youll eventually end up buying shocks, then mounts, then bushings. save up and get ST coils their good enough for what you need.
2006 BMW M3 VERT 6MT S/C VF570 (CURRENT)
2007 B7 AUDI A4 2.0T CVT FWD (BRILLIANT BLACK) TRADED
2002 E46 BMW M3 SMG II (TIAG) RIP
INSTAGRAM : @itsjorgebrah
nojoda is offline   Reply With Quote
Old 02-15-2013, 10:59 PM   #8
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
For DD usage, Eibach / HR springs and Koni shocks will be enough.
Using lowering springs will wear out your stock shocks quicker, but if your shocks are in good shape, you can wait before replacing them.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 02-17-2013, 11:12 AM   #9
emax
My Ride: 06 M3
Springs limit wheel travel and provide minimal improvements. As said above pair springs with quality shocks. Coilovers can greatly improve handling IF you get them adjusted and balanced correctly.
'06 CB/IR w/SMG/NAV/HK/19" BBS RGR/Hankooks
emax is offline   Reply With Quote
