E46 Xi Forum
Old 02-14-2013, 01:25 PM   #1
bikesandcars
My Ride: 2002 325xi-sport pkg
sport suspension getting rougher over time? what are my options?
I put Eibach pro-kit springs with Bilstein struts on my 2002 325xi about 4k miles ago. I also upgraded to powerflex bushings.
I have a LONG commute (80 miles each way), so maybe it's just too much time in the car... but..
It really seems like my suspension is getting rougher by the day... when I first installed the springs / struts the car seemed very tight. Now every time I hit a crack in the pavement it seems like it shakes the whole car. Is it possible for the suspension to get harsher and the bumps to get nastier in such a short amount of time?
This suspension is not what I wanted, so I'm seriously considering something softer... I'm not sure if it's the eibach's or the bilstien's or even the powerflex bushings that are contributing the most to the harshness. Does anyone have experience with softer setups or maybe has gone through this situation?
I should note that I bought the car 5,000 miles ago, and ran it with the stock suspension for a couple weeks. I thought the stock suspension was much better over these northeast highway potholes and big bumps.
There's one bump where concrete meets asphalt after a bridge that I hit every day.. with the stock setup it soaked it up pretty well,.. with this current setup it's "BAM".. makes me wince
bikesandcars is offline   Reply With Quote
Old 02-14-2013, 01:51 PM   #2
SamDoe1
My Ride: 4cyl of fury
The Eibachs will be stiffer than the stockers but not by much. I would check your install work and make sure the upper shock and strut mounts are still good. Also check the struts and shocks for leakage as they might not be working properly. Bilsteins have been known to leak.
The powerflex bushings will be stiffer than the stock ones too. You did overall stiffen the car quite a bit...
Old 02-14-2013, 02:01 PM   #3
bikesandcars
Install work is good, all new mounts. I'm not getting any rattles.. .just harsh
Maybe everything contributed a little huh.
I'll check the struts next time i have a chance... I'd hope they aren't leaking yet!
The rears seem harsher than the fronts, I don't have much weight in the car and the tires are set a few pounds less than factory recommended psi at the rear
Maybe I just need to go back to stock... I like the handling but 3 hours in the car each day is tough if you're counting cracks.
Old 02-14-2013, 02:19 PM   #4
e46alfonso
My Ride: 330xi MT, mustang gt
Eibachs and powerflex are fine, the problem is the bilsteins as they are known to be harsh especialy the rears. Return the rears and request e36m3 shocks.
I have no complaints with eibach/koni and PF combo and my roads are a disaster. Even with 255s all round the ride isn't that bad.
Old 02-14-2013, 02:59 PM   #5
shadow 2
My Ride: 07 328i
Koni sports much more livable than Bilstein with just as much handling.
shadow 2 is offline   Reply With Quote
Old 02-14-2013, 03:01 PM   #6
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
I'd just gotten eibach pro kit today and bilstein sport shocks. After many people saying bilstein is harsh and "too firm" I've decided to send the bilstein back and spend the extra $ on Koni sport for my 2002 xi. Good luck I'd hope they aren't leaking either. I know I'd heard many complain if that too, so I called turner motorsports where I ordered from and they advised that bilstein now ships the set with e36 m3 rears...?
Lou3viLL3sLuGGa is offline   Reply With Quote
Old 02-19-2013, 02:11 PM   #7
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
I will update when install is compete. Taking car Friday. Returned the bilstein sports for koni sport yellow and have eibach pro kit. Getting carbon fiber hood and trunk installed as well!
Old 02-19-2013, 02:30 PM   #8
bikesandcars
Are you getting Koni sports for the xi or for the e36 M3?
If it works out smoother I might follow suit. The front seems to soak up bumps better than the rear. The rear seems a little harsher... likely because I'm not loaded.
Then again, my E350 rides like S#$T until I have 1000 lbs in the back, maybe I should pick up some sand bags (joking)... what I really need is a suspenion designed for a car with one soul on board.
I wish I could get about 1" HIGHER in the front to help smooth things out. I think a slightly taller strut and softer compression dampening would do wonders (but also give a little more body roll).
Old 02-19-2013, 02:34 PM   #9
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
Koni sport and eibach pro going on 02 xi I don't have another car I was saying that turner motorsports had advised that the bilstein now ships with rear e36 m3 due to the issues reported.
Old 02-20-2013, 08:59 AM   #10
bikesandcars
I think you misunderstood my ramblings... I meant... are the Koni sport's specifically for the 2002 XI or are you buying e36 Koni sport rears for your 02xi
Old 02-20-2013, 09:08 AM   #11
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
They are specific to the xi
Old 02-20-2013, 09:26 AM   #12
SamDoe1
Koni makes an E46 Xi specific set up. That's the one you want, not one for the E36 M3.
Old 02-20-2013, 09:57 AM   #13
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
Exactly the only reason the e36 m3 was brought up is because I was advised that bilstein now ships their rears with the e36 m3 rear for all e46 by the tms rep. I opted to spend more money and get the koni sport yellow xi specific
Old 02-22-2013, 07:11 PM   #14
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
First impressions after getting car back today is that the setup is amazing. Koni yellow and eibach pro kit is soft for what it is! Very responsive and comfortable. I'm happy. It didn't get as low as I'd hoped, though I didn't want to be slammed. I hope it settles a bit, but I just think the xi sits higher in general and if I wanted to go real low I'd have needed h&r springs.
Old 02-22-2013, 08:31 PM   #15
SamDoe1
It should sit quite a bit lower than that after it settles, give it a few days to a week to get to it's final resting spot. Mine sits a lot lower than that on the same suspension.
Old 02-22-2013, 08:35 PM   #16
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
That's good to hear, as yours is also xi correct? Thanks
Old 02-23-2013, 10:25 AM   #17
SamDoe1
Yup, hence the car under my name to the left...and the reason I only post in this forum and OT.
Old 02-23-2013, 10:45 AM   #18
Lou3viLL3sLuGGa
My Ride: BMW 325 xi
Sorry I'm on the app for the iPhone and didn't see any of that but I was almost sure based on previous posts you were an xi owner .)
