The Showroom
Old 02-18-2013, 05:17 AM   #41
E92M
E92M's Avatar
My Ride: '08 ZCP M3 | '03 R6
Originally Posted by Andy2108 View Post
Why install rtab limiters when you could go to urethane ones which pretty much have limiters built in?
Will you be changing the sway bars? flywheel?
You could loose some weight by moving to a light weight battery.
I also went from a 330 to an M3. Before you go hard on the track make sure to reinforce your subframe and pull your valve cover to check the vanos bolts and hubs
Great progress so far! Sub'd
X2 ,
-Chris
E92M is offline   Reply With Quote
Old 02-18-2013, 05:56 PM   #42
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
RTABs - the bushing in this location needs to deflect. Therefore, the OE rubber bushing is superior in that it allows more suspension travel. Poly will cause the rear suspension to bind and create stress on the mounting area causing the mounting points in the floor to fail. The only better option than OE w/ limiters is to go with a bearing.
Sway bars are for fine tuning. I want to get the weight down first. Get the suspension setup and adjusted. Then use sway bars to make that last adjustment in the balance of the car.
Haven't really thought about the battery yet, that's easy. And I could use a lightweight battery now but the one in there works. Why waste?
I will track it one time without the subframe reinforcements...no cracks from what I can see and no clunking or banging from the rear (that's what she said). I will knock out a valve adjustment before this first event among other maintenance stuff. Definitely planned to check the VANOS.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 02-18-2013, 05:59 PM   #43
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Sorry to hear about the 330. PM me if you happen to have any good parts that can live on in my car, I'd love to get something, however large or small.
Nice progress on this M, very different build
hi its me alec is offline   Reply With Quote
Old 02-18-2013, 06:06 PM   #44
bigjae1976
bigjae1976's Avatar
Lost another 27 lbs today. So now I am at 237 lbs! I did add the center console and the glove box to the list. The trunk floor and carpet were 10 lbs! So I think my interior loss will be about 245 when I get the carpet and some of the airbags out.
3 - rest of carpet
5 - side and curtain airbags
Always solder your crimped terminations...
Installing some wire loom to protect the wires.
Removed the windshield washer resorvoir
Floor plate installation.
Footwell is its most naked form
Drilling holes for the floor plate. That's right above the fuel filter. careful when the drill bit punches through. Not a big deal for me...need to replace it and got one on the way.
Also close to the fuel filter
Hole at the top of the pic...
I RTV'd the spacers to the floor and the hole to prevent water and dirt from getting in. I will spray undercoating under the car when I take the fuel filter out.
Driver's slide floor plate is installed...look hideous but its functional. Has a lifted jeep feel to it.
Old 02-18-2013, 06:11 PM   #45
bigjae1976
bigjae1976's Avatar
Here is tomorrow's to do list...
1. Install driver's floor plate DONE
2. Remove front carpet on pass side
3. Install pass floor plate
4. Remove curtain airbags
5. Remove washer resorvoir and linesDONE
6. Install V1 hardwire (yes, still will drive this to the track)DONE
7. Install a lightweight and removable radio IN PROGRESS
8. Stoptech 355mm/4 wheel BBK and brake duct plates
9. TMS Rear control arms and RTAB limiters
10. Powerflex FCABs
11. Front struts w/ camber plates
12. Adjustable end links
13. Install UUC SSK and DSSR (will do tonight)
Old 02-18-2013, 06:15 PM   #46
bigjae1976
bigjae1976's Avatar
Thanks! I am still sad and STILL think about keeping the 330 as a nice DD but then I'll have 4 cars.
Actually, this M3 is turning out to be very similar. The 330 was going in this direction. I was stalling and then the car broke down before I could get there.
Here's a list of what I have left...
http://forum.e46fanatics.com/showthread.php?t=971143
Old 02-18-2013, 06:20 PM   #47
BrainofJJJ
My Ride: SPEC E46, 17 CTSV
Come up to Dallas and help me do mine please. Got seats and harnesses on the way along with some new wheels. Lots of stuff to figure out still.
Thanks for all the photos and weights, will help a lot this spring
BrainofJJJ is offline   Reply With Quote
Old 02-18-2013, 06:21 PM   #48
cyberkaa
My Ride: E46 332i,M3;E30 325i
Very nice progress!
I'll buy your windshield washer reservoir, pump, etc. if you're getting rid of it.
-Kalim
(klx photo studio)
Old 02-18-2013, 06:24 PM   #49
bigjae1976
bigjae1976's Avatar
Come down to Killeen!...we can knock most of this crap out in a days work with two of us going at it.
Originally Posted by cyberkaa View Post
Very nice progress!
Sure. PM me an offer shipped from 76542. Only the resorvoir is intact. I have some parts from the lines but I just cut most of it. And the headlight washers are still in the car...not sure if need them.
Old 02-18-2013, 06:27 PM   #50
cyberkaa
PM sent.
-Kalim
(klx photo studio)
Old 02-18-2013, 06:28 PM   #51
GotVANOS?
My Ride: 2003 325xi Touring
Poor man's CSL haha
Shes not your average grocery getter. This 2.5L of fury doesnt mess around.
E21<E30>E36>E46>E90>F30
5TFUUU, If one more person tells me to sell my car and buy an ///M Im going to light their family on fire and make them watch.
*****BUY MY 330XI AUTO TRANS AND PARTS. CHEAP!!!******
GotVANOS? is offline   Reply With Quote
Old 02-18-2013, 06:33 PM   #52
bigjae1976
bigjae1976's Avatar
Originally Posted by GotVANOS? View Post
Poor man's CSL haha
Old 02-18-2013, 06:41 PM   #53
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yessssssssss. Love it!
Old 02-18-2013, 10:46 PM   #54
bigjae1976
bigjae1976's Avatar
Got the OE shifter out. Gonna finish the SSK install tomorrow.
Drove it for the first time since stripping it out. It feels so much quicker! I love it!
Old 02-20-2013, 04:04 AM   #55
bigjae1976
bigjae1976's Avatar
UUC SSK + DSSR done. WHAT A PIA! The delrin bushings that fit into the carrier were all wrong. Ain't no way in hell it was going to fit so I did some filing...a LOT of filing. So it finally slid in. Then the pin did not fit. NOT even close! I did some drilling. And more drilling. Even then, I had to get some cutters up there to hammer the pin in an area where there is no room. I remember installing the UUC SSK + DSSR into my 330...it was a major PIA. I even considered taking out the transmission. So you'd think I would learn my lesson...apparently not.
Installed a new fuel pump. Why? I bought one for my 330 a month ago before I decided to sell. So its just collecting dust, figure I would put it to good use. Changed the fuel filter, very different from a non-M and more of a PIA...a minor one. I decided to suck out the old p/s fluid and replace it with some new D4ATF. I took out my fabulous injen intake which then took an entire hour to put back in because its so f'ing tight.
Checked the guibo, tranny mounts and engine mounts...usually they are trashed...mine look brand new! So surprised!
Tomorrow...
Change the oil, coolant, and gearbox fluids. Hopefully install the rear camber arms. Check the RTABs and if they are good, install some limiters. If not, order some RTABs and wait...
Old 02-20-2013, 04:57 PM   #56
Tate325xi
My Ride: 325xi 5MT
Isn't the 330 fuel pump different from the M3 fuel pump?
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 02-20-2013, 05:05 PM   #57
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Looking good so far.
AMG-ETR is offline   Reply With Quote
Old 02-21-2013, 09:51 PM   #58
bigjae1976
bigjae1976's Avatar
Today, I cut off the brake dust shields in prep for the BBK. Much to my dismay, I had to drill out 3 rotor set screws in the front .
Drove it with the SSK for the first time, way better! In negotiations for a 4.10 diff. Need to finish removing the pass carpet.
But I'm really just waiting on parts.
Yes but the m3 pump fits the 330.
Old 02-21-2013, 10:47 PM   #59
Grande D
My Ride: E36 M3
So why did you need to run wire, and why did you drill the floor? For spacers for the floor plate? Why not just install the spacers on the floor plate itself?
It will change your life!
Old 02-21-2013, 11:41 PM   #60
serdar255
My Ride: '01 325ci / '90 325i
I love this thread.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
