Big Jae's M3 build - a street legal track car for HPDEs and drifting - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Old 02-28-2013, 05:38 PM   #81
secono330ci
My Ride: 04' 330ci/15' A3 TDI
+1 on AKG
Are you going with the carbon fiber sunroof delete?
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 02-28-2013, 09:04 PM   #82
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
1. Install driver's floor plate DONE
2. Remove front carpet on pass side DONE
3. Install pass floor plate DELETE
4. Remove curtain airbags
5. Remove washer resorvoir and linesDONE
6. Install V1 hardwire (yes, still will drive this to the track)DONE
7. Install a lightweight and removable radio IN PROGRESS
8. Stoptech 355mm/4 wheel BBK and brake duct platesduct plates DONE
9. TMS Rear control arms and RTAB limiters DONE
10. Powerflex FCABs DONE
11. Front struts w/ camber platesDONE
12. Adjustable end linksDONE
13. Install UUC SSK and DSSRDONE
So there's the list. No more pics...nothing really exciting.
TC Kline saved me $430. I ordered the Vorshlag M3 camber plates for the TCK coilovers. Out of stock..waiting...called TC Kline (the actual guy) and he said it would work. And it DOES! It drives fine, about to get it aligned tomorrow. But I have plenty of camber just from eyeballing it. Awesome!
I did the RTABs, FCABs, drained the diff oil, replaced the hood cowl, and attempted the rear control arms. One thing I've noticed...you'll need to remove either 50% more bolts and a bunch more plastic covers on and M3 vs doing the same job on an 330.
When I did the FCABs.. WHAT A PIA! The bolt hole in the bottom of the housing didn't line up with the reinforcement plate. After trying to use a 3lb sledge to coax it into lining up, I busted out the step drill bit and made that hole line up. Then added a big washer for good measure. I AM professional! Lol. These were PF bushings already pressed into the housings.
So (hopefully) off to the alignment rack tomorrow. She MIGHT, I said MIGHT be on the track in 2 days!
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 03-01-2013, 08:47 PM   #83
bigjae1976
bigjae1976's Avatar
Ok, BIG NEWS! The car will go on track tomorrow for the first time!
Here is what the brake fluid that came out looked like...
I've invented a new super lightweight glove box...
Old 03-01-2013, 10:24 PM   #84
lab rat
My Ride: '02 330iT
I assume 5spd for saving weight?
I don't quite understand hanging onto the stereo in a car that's this serious about weight loss.
Great build (or tear down in some cases )
Because sleeper
Old 03-02-2013, 08:39 PM   #85
bigjae1976
bigjae1976's Avatar
I got to drive it on the street once in awhile. No stereo gets kind of old, with an extra 30 lbs.
Yeah, 5sp saves weight and is cheaper to fix/replace. 6th gear is useless on the track.
Old 03-04-2013, 08:52 AM   #86
bigjae1976
bigjae1976's Avatar
Here it is...first weekend on the track. No issues. The NTB alignment wasn't on so the rear felt quite twitchy through the faster turns. Unfortunately, that kind of hurts you pretty had at this track where most of the turns are pretty fast. But I can easily see with a little more setup work how the M3 in stock form will beat my 330's best of 1:57:32 at this track.
The first thing I need to do is dial out some of the -4.5 degrees of camber I have upfront. Then add a little more camber in the rear with some more toe in at the rear. I'm thinking about dropping the rear a little bit too.
Old 03-04-2013, 09:26 PM   #87
Grande D
My Ride: E36 M3
It does look like the car got a bit squirrely! What's the one biggest difference you noticed between the M3 and the 330 this first time on the track with it?
It will change your life!
Old 03-04-2013, 10:01 PM   #88
bigjae1976
bigjae1976's Avatar
Yeah, had way too much neg camber in the front...-4.5! This was just more of a dry run.
First, a lot less shifting with the 8k redline. The throttle is a lot more consistent and easier to modulate. Overall, it's just a lot better to drive.
I am off 8-9mph on the front straight but i can cut a lot of that difference once I get the car to be less oversteery. Plus, I was fighting a strong headwind. This car is every bit as capable as the 330...and no issues! I'll be topping my 330 personal lap records soon enough on stock power!
I just need to get the trail braking down in this car.
Old 03-05-2013, 09:10 AM   #89
bigjae1976
bigjae1976's Avatar
I've been thinking about the setup. I figure that the M3 stock is more nose heavy but its probably lighter than the 330 since it doesn't have 80lbs of extra crap over the front axle (supercharger, oil cooler, other crap). I'm going to drop down to -3.0 degrees of camber in the front. I will mark the plates and tie rods for street settings, -3.0, and -3.5 degrees of camber. I may also drop the rear height as well.
Old 03-05-2013, 09:41 AM   #90
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
Sounds about right, both should help to to keep the rear end in check. Upping front rebound a bit may help as well in terms of modulating the trail braking. I'm living vicariously through you!
Chris
dreamdrivedrift is offline   Reply With Quote
Old 03-06-2013, 03:17 AM   #91
DamoBMW
My Ride: '02 325Ci M-Sport
I've heard good things about CSL boots in terms of rear down force on the track. Maybe something you could consider?
'02 BMW 325Ci 5MT M-Sport Individual Stratus Grey
DamoBMW is offline   Reply With Quote
Old 03-06-2013, 06:28 AM   #92
bigjae1976
bigjae1976's Avatar
I don't think they will make any difference other than some weight loss. If I were going with crap on fiber then I'd go with the hood. I need to start looking at ways to take weight off of the front axle.
Yes, I am the anti exposed carbon fiber guy.
Old 03-06-2013, 06:36 AM   #93
DamoBMW
Fair enough. I just remember someone on this forum saying that he noticed a difference on the track and even cut down his lap times so thought I would just pass the info on. Can't remember who it was though.
Anyway, awesome project man!
Old 03-06-2013, 06:42 AM   #94
WALKD U
My Ride: Just Fast!
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 03-13-2013, 09:10 PM   #95
bigjae1976
bigjae1976's Avatar
Update.
I got a stereo installed! Tunes, YAY! Now, getting the rear refreshed and hopefully (if there's time) reinforced. New front diff seal, solid subframe mounts, 6 new control arm bushings, adj control arms and maybe diff mounts. Holding off on the 4.10 for now...got more pressing things and I'm not sure...might go with a 3.91...might do a 5sp swap now and wait until I get a tow truck and trailer to throw in the 3.91 or 4.10...hard decisions.
Got some bad news. Did an oil analysis, it shows some bearing wear and it had 5w-30 in it. Good thing is I looked at the oil before changing it and it was golden in color so I assume it was new. So crossing fingers that this is the first 5w-30 oil change. The other bad news is it shows some bearing wear. The car runs fine...can't do anything but keep good fresh oil in it and keep doing the oil analysis. Engine runs fine, no noises so I'll just keep driving it. The plan was to start looking at buying a used engine in preparation for the inevitable over the next 1-2 years...might need to speed that up a little.
Last two tasks...alignment (-3.5 camber in front this time!) and BBKs. Then off to Motorsport Ranch for another track weekend.
Now to represent my sponsors, here's the first one...
Old 03-13-2013, 10:20 PM   #96
djnekkon
My Ride: MB3ci & z33 HR
awesome car, but tell your sponsor to pay a designer to make a logo that suit your car better.
Old 03-13-2013, 10:45 PM   #97
bigjae1976
bigjae1976's Avatar
Its a track car...I think it looks fine.
Old 03-13-2013, 10:46 PM   #98
bigjae1976
bigjae1976's Avatar
4. Remove curtain airbags DONE
7. Install a lightweight and removable radio DONE
List almost complete...just need to install the BBK. I could if it were here Time for a NEW LIST!
Old 03-14-2013, 04:19 PM   #99
rohde88
rohde88's Avatar
My Ride: S2000
Update.
G]
Are you running MSR on 3/23-3/24? I'm going and its the big 3.1
-Ron
rohde88 is offline   Reply With Quote
Old 03-14-2013, 05:22 PM   #100
bigjae1976
bigjae1976's Avatar
I should be there...
