Sponsored by BimmerWorld
Old 11-05-2013, 08:12 PM   #1
simerak
My Ride: Alpine 330
Bent strut tower assembly worth fixing
ID:	533506I hit a curb hard trying to avoid an accident and my strut tower is shot, torn from the frame and bent. I found an assembly on eBay. Is this fixable and what might this cost me for labor. Would a machine shop or a welder be able to tackle this? Everything else looks fine just the front camber is at about -20. Any advice is much appreciated.
simerak is offline   Reply With Quote
Old 11-05-2013, 08:28 PM   #2
wildirish317
My Ride: 2004 325Ci vert
That's a question for a good body shop. Expect a few "it'll buff right out" comments, but that's pretty serious damage, beyond the shock tower itself; but you know that. Given enough money, anything can be fixed.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 11-05-2013, 08:51 PM   #3
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
You can replace that whole section of the body, the question is would it be worth the cost. You'll have to get an estimate from a body shop to know how much you're going to pay. Pretty much all shops will give you a free estimate. Just shop around.
Drew@Swift Motorworks is offline   Reply With Quote
Old 11-05-2013, 09:21 PM   #4
scarede46er
My Ride: 2001 BMW 325i ZSP
Do you not have insurance?
Old 11-06-2013, 02:05 AM   #5
asma123
My Ride: E70x5 m3conv m3coupe
I had something like this happen before. same -2 camber.. What I did is remove the strut and hammer down the strut tower to make it flat.
You will need the strut reinforments as well as a new strut mount.
asma123 is offline   Reply With Quote
Old 11-06-2013, 08:11 AM   #6
simerak
My Ride: Alpine 330
No full coverage, do you think I should buy a replacement assembly or just leave it up to the body shop it's actually my daughters car and am trying to keep the cost down. Thanks for the advice.
Old 11-06-2013, 08:23 AM   #7
///M Protocol
Banned User
My Ride: i3
if you are concern with short term or immediate cost then I say just pound the strut tower to make it as flat as possible. however, you will incur long term cost associated with this band aid fix because things that comes naturally from having a bad alignment (uneven tire wear, vibration, etc)
///M Protocol is offline   Reply With Quote
Old 11-06-2013, 08:30 AM   #8
Blueandwhite85
My Ride: E46
Re: Bent strut tower assembly worth fixing
Post a picture of your entire engine bay. (For the birds)
Blueandwhite85 is offline   Reply With Quote
Old 11-06-2013, 03:07 PM   #9
simerak
My Ride: Alpine 330
I wonder if I did just straighten it out and put a tower brace, along with a hat reinforcement if that would work??
