Old 02-14-2013, 10:25 PM   #1
NukeMiller
My Ride: 2005 325i
MS45 vs MS45.1
Besides some transmission lags at a certain RPM, is there anyone who knows what "fixes" were made...Dealer wants 430 to do the flash...Not sure that is worth it...I have the software to do it, but not the confidence nor a battery charger
NukeMiller is offline   Reply With Quote
Old 02-14-2013, 10:46 PM   #2
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
MS43 vs MS45.1
MS43 has 3 wire MAF and a seperate AIT sensor in intake
MS45.1 has 5 wire MAF (that incorporates the MAF and AIT into one) and a seperate MAF on the SAP
/_________\
O==[][]==O
Old 02-14-2013, 10:46 PM   #3
330i ZHP
330i ZHP's Avatar
DMEs and wiring harnesses are NOT interchangeable
/_________\
O==[][]==O
Old 02-15-2013, 02:41 PM   #4
NukeMiller
My Ride: 2005 325i
I understand that...I'm asking about the diff between MS45 and 45.1...like what did BMW change to require this software upgrade....I have already realized that my car buying decision was bad when I read about the M56
Old 02-15-2013, 04:58 PM   #5
330i ZHP
330i ZHP's Avatar
I do not know of MS45 DME except when used with the M56 SULEV engine - so, in that case - the two DMEs are NOT interchangeable
/_________\
O==[][]==O
Old 02-15-2013, 05:04 PM   #6
NukeMiller
My Ride: 2005 325i
Maybe I'm not explaining this properly...I have the M56 SULEV garbage motor....I have the MS45 DME...I'm trying to figure out what the MS45.1 software upgrade actually provides...I appreciate you trying to help though...That is a sick looking 330i
Old 02-15-2013, 05:28 PM   #7
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
MS45.0 & MS45.1 DME's were introduced in the US Markets in 03/03 on both the 325i, 330i ZHP & SULEV. This ECU was then later used on the early 04-06 Z4 2.5 & E60 530i's as well. Since you have a M56 you are a SULEV BMW made this change for US Spec vehicles for cleaner Emission Purposes.
The Fuel Injection system in M56 is completely different than that of a M54.
Last edited by Viral@ActiveAutowerke; 02-15-2013 at 05:29 PM. Reason: Auto-save 1360967376
Viral@ActiveAutowerke is offline   Reply With Quote
Old 02-15-2013, 05:32 PM   #8
330i ZHP
330i ZHP's Avatar
I do not believe the MS45.1 DME will work on the M56 engine
/_________\
O==[][]==O
Old 02-16-2013, 07:16 PM   #9
TerraPhantm
My Ride: M3 & ZHP
As far as I know, MS45.0 = Europe and MS45.1 = US. Euro E46s never got either, but cars like the Z4 and E60 did get the MS45.
Old 02-19-2013, 01:53 AM   #10
daniel_f.
My Ride: 330iC
correct! MS45 is using narrowband sensor and MS45.1 is using wideband, therefore the parts arenīt interchangeable, as the hardware is different.
Iīm currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 02-19-2013, 02:41 AM   #11
NukeMiller
My Ride: 2005 325i
Right on...Thanks guys...no need for me to take action then...
Old 02-24-2013, 09:21 PM   #12
TerraPhantm
My Ride: M3 & ZHP
Doing a little bit more research, in the US, the Z4 came with the MS45.0 as did the X3 2.5i (but oddly, the 3.0i got the MS45.1). You are correct in that the difference seems to be wideband vs narrowband sensors.
Old 02-25-2013, 12:38 AM   #13
daniel_f.
My Ride: 330iC
I have a MS45.1 laying around and i would like to do the convertion from MS43 to MS45. Does anyone know if there is a possibility to build an adapter between the stock MS43 harness and the MS45 ecu? i donīt want to re-pin all the wires directly.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 02-25-2013, 11:30 AM   #14
TerraPhantm
My Ride: M3 & ZHP
I'm sure you can reuse the vast majority of the stock harness, but some changes will still have to be made. Extra pins for wideband sensors, extra wiring for SAP MAF, and... Actually that's probably all. And unless you can tune your ECU, I imagine that you'd need to use the 5-pin MAF as its unlikely the MAF and its temperature sensor follow the same curves as the ms43 hardware.
I also suspect that the MS45.1 and MS45 are largely similar. I would not be surprise if you can convert from one to the other with a bootsector and program update.
Old 02-27-2013, 12:42 AM   #15
daniel_f.
My Ride: 330iC
Actually i donīt think BMW wanted the same hardware inside the DME, as wideband needs definately different hardware components. But as i havenīt opened a MS45.0 iīm not shure.
nevertheless i would prever the ms45.1 because of the capability using wideband.
i know which wires to change, i just donīt want to change the stock harness.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 03-02-2013, 03:29 AM   #16
TerraPhantm
My Ride: M3 & ZHP
Eh, I'm 99.9% sure the hardware is the same. The pinouts are identical except that the MS45.1 models use a couple extra pins (corresponding to the extra wires required by wide band sensors). A DME that is meant for wide-band O2 sensors could be reprogrammed to use narrow-band sensors -- this wouldn't be particularly difficult if you have access to the source code as BMW does.
Old 06-02-2013, 03:43 PM   #17
Alun1976
My Ride: BMW Z4
Benefit of narrowband over wideband sensors
What's the benefit of wideband sensors? Is it just the O2 sensors? Does it improve fuel economy by keeping AFR closer to stoichiometric value?
Cheers
Alun1976 is offline   Reply With Quote
