///M3 Forum
Old 02-14-2013, 03:22 PM   #1
dillard
My Ride: 2004 M3 Cabrio
Alignment after FRONT CABs?
Doing my front control arm bushings this weekend. Will I need to realign?
Proud owner of '04 M3 Convertible:
dillard is offline   Reply With Quote
Old 02-14-2013, 03:38 PM   #2
choxor
My Ride: JDM
Usually no, changing FCABs won't change alignment. However, if the car was aligned with worn components it may be changed after they're replaced.
choxor is online now   Reply With Quote
Old 02-15-2013, 12:13 AM   #3
illestminimike
My Ride: Project Drama
You don't "need" to but if you don't mind then it isn't a bad idea to do it. But you definitely need one if you do RTAB's.
Old 02-15-2013, 03:59 PM   #4
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
When I had my FCABs replaced under warranty at the dealer they replaced the arms as well which required an alignment - it would be a good move for you to have an alignment done afterwords to ensure it is still in spec, as "choxor" said, if the last alignment was done with worn out components it will more than likely need to be adjusted.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 02-15-2013, 04:08 PM   #5
Mf3st
My Ride: e46M3
do I have to do alignment when I dropped the rear approximately 1/2 of an inch more?
Mf3st is offline   Reply With Quote
Old 02-15-2013, 04:36 PM   #6
scca_ziptie
It wouldn't be a bad idea but it doesn't have as much effect compared to the front. Personally I would if it were mine but that's just me - I'm a bit "picky."
