Old 02-15-2013, 11:04 AM   #1
mike@maximumpsi
My Ride: 02M3T
Maximum PSI E46 M3 turbo kit - current status 2/15/13
EDIT 2/16/13:
6 speed catless - $9800, catted $10000
SMG catless - $10000, catted $10200
Catless run from today:
Twin scroll T4 tubular header
Catless downpipe
Stock section 2
Stock muffler
93 octane, 8.4psi
455whp/334tq on our Superflow dyno
Hi Guys,
We are working extremely hard to bring together the final dyno numbers for the SMG and 6 speed kits, and also catted/catless results. I prefer to be as transparent as possible, so I would like to give a run-down of what is currently going on at the shop:
For those of you following, there are currently three cars with variations of our E46 M3 turbo kit up and running:
My car(02 6 speed) has a ton of miles on it turbocharged and is running great. Most of those miles were with the initial Steedspeed manifold. I will get to its current state in a bit.
Brian's E46 is our first customer car, an 04 6 speed. He was the first to get our tubular manifold, and he opted to run a stock mid pipe, his current aftermarket muffler, and an open dump. His car made excellent power up top, and the boost control was acceptable, although it did creep a bit as rpm increased. On the dyno it was a non-issue. He took the car and has put a bunch of miles on it and has posted his own thread on the forum. We recently found that in 6th gear with more load, the boost is creeping even higher than desired. I asked Brian to bring us back his car for hardware revisions and a software tweak as well. It is currently in the shop, and we will have the modifications finished shortly.
In the mean time, we finished Dexter's 04 SMG install with the same header as Brian's, a recirculated wg, catless mid-pipe and aftermarket rear muffler. We put it on the dyno and noticed several things. Boost was creeping way worse than Brians, and power was also lower at the same boost level. We pulled off his turbo, header and downpipe and made some revisions. We got the new hardware installed and put it back on the dyno. Boost was now rock solid, however we were still down in power from Brian's car. We did some tests and found that his aftermarket muffler was robbing a bunch of power compared to stock. We also found that Dexters car had 10+psi more compression than my car and Brian's car. When it was NA we saw that his knock adaption was pulling 4 degrees timing out of the ignition maps. Sure enough, it wanted about 4-5 degrees less timing compared to the other two cars. It looks like there was some top end work done at some time, and likely the head was decked a bunch. Dexter currently has his car, and is waiting on results from my car to see if we will make a change to a larger turbine housing to pick up some more top end power. It spools up faster than Brian's car due to the new header/wg mods. The SMG system is working nicely with the turbo setup.
After seeing the results from Brian's car and Dexter's, I pulled the hot side components off of my car and made the same revisions as Dexter's. Over the past week or so I have about 50 dyno runs with numerous different configurations, and I am very happy with the response, boost control, and top end power of the setup. The current catted vs catless results are also very promising for those looking to run catted, full sec 2 and stock muffler. That said, I have one last change to test before posting up dyno results for everything. This coming week I should have dynojet results for my car with the final catted and catless setups through the stock section 2 and muffler.
Thanks for all of the interest in the kit, and for holding out for results/info. It really is worth the wait. I believe the setup going on my car this weekend will be the final hardware swap that will give us the best overall powerband.
-Mike
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
Last edited by mike@maximumpsi; 02-16-2013 at 02:47 PM. Reason: Auto-save 1361047679
mike@maximumpsi is offline   Reply With Quote
Old 02-15-2013, 12:05 PM   #2
Commanderwiggin
My Ride: 900rwhp Turbo M3
Great work guys!
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 02-15-2013, 12:35 PM   #3
E85head
My Ride: E46 M3
Transparency: The marketing strategy of tomorrow!
Thanks for letting us know how your kit is developing!
Kudos!
E85head is offline   Reply With Quote
Old 02-15-2013, 12:41 PM   #4
JohnBlaze
My Ride: Black Sunshine
can't wait to see those catted results over here
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 02-15-2013, 12:50 PM   #5
Grendelsbane
My Ride: M3
Like what you guys are doing! Just wish you were closer.
2004 Silver M3 / SMG / Koni Yellow shocks and struts / Vogtlands lowering springs / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / Laser Interceptors / Clear Bumper Reflectors / Mishimoto Aluminum Radiator / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune
Grendelsbane is offline   Reply With Quote
Old 02-15-2013, 04:52 PM   #6
95silverM
My Ride: 05' IB M3
Mike, thanks for taking the time to give us an update.. Look forward in seeing the results.
Im taking time to decide a few factors on my build, i may be looking on going with a stroker (3.4-3.5) on my build.. any insight on pairing that and a 6766 CEA?
05'IB/Blk M-Cloth 6spd NoSunroof-SOLD
Eurotechniks
EliteEuroCarsLLC.
E46 M3 6-Spd Coupe Roller *WANTED!*
2JZGTE:9.68:1WiscoPistons&ManleyIBeamRods,
GSCS2BilletCams,GSCSprings&TiRetainers,FerreaValves,CustomTurboManifoldw/PTE66mmWG,Pro-EFI,Custom Dash,CAE Shifter,ABCTiltonTripleDisk,E46M3 6-Spd,18x9et31&18x10et.27EC-7's,R888's,WeldedHalfCage&SubframeBrace,& Lots More
B5-S4:BLK/BLK 6-Spd SingleTurbo Shop-Car:In progress..
95silverM is offline   Reply With Quote
Old 02-15-2013, 04:58 PM   #7
E85head
My Ride: E46 M3
This!
Old 02-15-2013, 05:31 PM   #8
kidrobot_
My Ride: 2003 M3, 2001 330i
^wonder if the better strategy is to underbore it, if boost is what you're after. Or just build the internals and leave the block alone.
Would be interesting to compare differences in the S54 v the other top teir I6's like the RB and JZ.
I'd research to find out but I'm too lazy...
kidrobot_ is offline   Reply With Quote
Old 02-15-2013, 07:07 PM   #9
mike@maximumpsi
My Ride: 02M3T
I would stay with as close to standard bore as possible.
My car is back together again so its Dyno time tomorrow!
Old 02-16-2013, 09:03 AM   #10
rboostedm3
My Ride: 04 bmw m3
What's the price on the kit? Please pm me thanx
rboostedm3 is offline   Reply With Quote
Old 02-16-2013, 02:46 PM   #11
mike@maximumpsi
My Ride: 02M3T
Catless downpipe
Stock section 2
Stock muffler
93 octane, 8.4psi
Old 02-16-2013, 02:54 PM   #12
TiAg2247
My Ride: E39 M5 | E55 AMG
Nice! Glad to see it's complete and available for customers.
Imola Red M5 | Imola Red Interior
GT Exhaust, Custom BC Coilovers, 19x10 + 19x11 Rial Dayonta Race, Michelin PSS
Daily: 335i M-Sport Alpine White / Coral Red
Too many mods
Past:
'04 E55 AMG
'01 330Ci Titanium Silver / Coral Red
'96 328i Jet Black / Black
TiAg2247 is offline   Reply With Quote
Old 02-16-2013, 02:55 PM   #13
mike@maximumpsi
My Ride: 02M3T
Prices posted above. Give us a call during the week to set up a test drive!
Old 02-17-2013, 05:20 PM   #14
bmxpert86
My Ride: e46 TiAg ///M3
Nice work guys's. I'm very very interested to see how everything comes together with more miles on the kit. You guys are not to far off the route of my bi monthly Atlantic City and Philly casino trips. I'll be checking this thread often and I appreciate your business ethics already. I have an 04 6spd coupe and I'm thrilled you guys already have been working on 03.5+, and are able to sort the bugs out with the newer model e46 M's. Good luck with everything and hope to be f/i sometime in the near future. Finally your good rep in the e36 crowd is moving on to our platform.
bmxpert86 is offline   Reply With Quote
Old 02-21-2013, 06:17 PM   #15
m3816
My Ride: M3 e46
I have a few Questions
>What type of gain can I expect with 50/50 meth ?
I>s there an option for more boost if so how much and what is the ball park expected whp ? (I have enough more the enough fuel capability also I am looking to build my bottom end soon, so I am considering all my options)
THANK YOU FOR LOOKING OUT FOR THE S54 Community
m3816 is offline   Reply With Quote
Old 02-21-2013, 09:45 PM   #16
Korpe schmin
My Ride: 2006 BMW 330ci
I'd happily pay 10k to see that on my dyno run. the only problem for me being I'm in a '06 330ci, not an M.
Korpe schmin is offline   Reply With Quote
Old 02-22-2013, 10:49 AM   #17
luke@maximumpsi
Past Site Sponsor
My Ride: 750hp E36 NickG Tune
We don't want to speculate on the potential gains from meth, but from our experiences, the gains from meth are similar to the gains seen from 109 octane.
For the stock motor, we are working on higher boost options for both 109 octane and E85.
We currently have a built motor car we are building in house. Feel free to give us a call if you are looking for a build along those lines.
luke@maximumpsi is offline   Reply With Quote
