///M3 Forum
Old 02-15-2013, 12:51 PM   #1
TitanSl33pr
My Ride: 330ci
Storing my SMG for the next 10 months...
Good morning everyone. My 03SMGM3 will have to be stored for the next 10-12 months. My Fiancee has been tasked with starting it and taking it for a short drive around the block once, biweekly. What is your experience and suggestions for properly preparing this beast for storage?
Sent from my Samsung Galaxy using Bimmer App
TitanSl33pr is offline   Reply With Quote
Old 02-15-2013, 12:58 PM   #2
///M Powerd
My Ride: 2003.5 M3 Coupe
I thought short drives were bad for these cars, but maybe its just M3s. I thought u should take longer drives to allow the engine/oil to get up to temp and allow the alternator to charge the battery. Also getting a battery tender is a good idea.
///M Powerd is offline   Reply With Quote
Old 02-15-2013, 03:15 PM   #3
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Short drives = bad for an ///M. The fluids won't get up to proper temperature among other things. Make sure she drives it for at least 20 miles, ensuring proper operating temperatures are achieved. As "///M Powered" stated, a battery tender is also a good move to keep the battery from becoming weak or actually failing. Placement of moth balls around the car on the ground and some placed inside the engine bay are also a must to keep the critters from making themselves at home and potentially wreaking havoc on your wiring harness (have personally seen this twice - 1 on a Miata and the other on a 46 ///M - both of which were hugely expensive to correct).
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 02-15-2013, 09:12 PM   #4
TitanSl33pr
My Ride: 330ci
Thanks for the feedback and suggestions. Although I stated that she would go for short drives, it was more figure of speech. I definitely will take heed to these suggestions.
Sent from my SPH-L710 using Bimmer App
Old 02-16-2013, 01:55 PM   #5
CroVlado
My Ride: 2004 MB BMW M3
park it, put it on a battery tender, and drain the fluids. should be fine to sit all year then.
CroVlado is offline   Reply With Quote
Old 02-17-2013, 11:46 AM   #6
kaput
My Ride: 2002 M3 SMG
Send a message via AIM to kaput
My car sat for 14 months straight, with a dead battery attached, flat tire and a broken LCM. I replaced the LCM and replaced the battery, turned the key and it fired right up. No CEL, no issues what so ever. It was like it was parked yesterday.
2002 M3
kaput is offline   Reply With Quote
Old 02-17-2013, 12:05 PM   #7
Blocked Out
My Ride: Imola 330i M-Sport
Omg, some replies on here are plain retarded ! Drain the fluids??? Imagine this facepalm but 100 times bigger, that what i did when I read it.
If you park it for that long , you need to store it with wheels off of the ground in order not to flatspot your tires. Store the car on jackstands with wheels off the ground. Full tank of 94 gas in the tank and a bottle of fuel stabilizer. Take the battery right out of the car, you dont need to for 11 months, there is ABSOLUTELY no point of keeping it and charging it for that time.
Thats it, just let it sit , dont start it in between (it does absolutely nothing to the car).
Nothing happens to the car if it just sits for a year, as long as its off the ground and sits in a heated garage so it doesnt rust. If you worry alot, you can spray ALOT of WD40 on your brake rotors so they dont form a rust glare.
When you take it out of storage , pour a quart or oil in BEFORE you start. Why? because after a yea of sitting all the old oil will drain into the pan, and little to no oil will remain in the top end that insures proper protection during initial start up. You can drain and change oil after a few hundred miles.
Original BMW Teile ///
IMG_1725
Old 02-17-2013, 09:31 PM   #8
TitanSl33pr
My Ride: 330ci
Sounds more like that's what I want to do. I initially wanted my Fiancee to drive it periodically, but I am still leaning towards setting it on jack stands and adding Stabilizer to the tank and lubricating the rotors. Thanks for the feedback
