Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Reman rear axle or new OEM?
Hello,
Should i get my oem axle rebuild? Buy a new OEM one for $199, or buy another rebuild brand? Thanks |
#2 |
OEM.
$199 is little money to pay for a critical component you'll probably never replace again. That said, you weren't quoted the cheapest price. It can be purchased for less. Last edited by Stiggles; 02-15-2013 at 07:28 PM. Reason: Auto-save 1360978128 |
#3 |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
How much does it cost to rebuild a rear axle?
E46Fanatic's resident mathemagician
#4 |
well IDK its 100k on the car and the OEM one gave out. Where can I find it for less?
#5 |
#6 | |
Main point here is BMW axles are not a major problem component.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” |
#7 | |
#8 |
Do a search for axles. Not saying there aren't any, I just haven't seen any in the five months I've been on this forum. Check your expansion tank though. lol
#9 |
I'm assuming the boot is torn? That's life, nothing out of the ordinary there. For $200, a new axle is a no-brainer. They're $350-$500 for an e30.
#10 |
#11 |
#12 |
Put a FLAPS reman on a Honda Civic, but get an OEM axle for your car. The component & material quality on the remans is sketchy. They can leak, break, and wear quickly. Once the new OEM is in, that's the last time you'll have to think about it. Yours failed at 100K but if the boot was torn and the CV lost its grease 20K ago all bets are off.
#13 | |
The axle is a bigger problem as it vibrates, well my right rear wheel seems to have the chamber messed up as the rear tire is cupping on the inside maybe it's just that. Maybe ill get an alignment first and see if that stops it. Secondly, completely off topic. I'm getting really low MPG. 20MPG mostly highway 40-55mph!! I drive like a grandmother. Would a messed up axle or chamber cause that significant of a drop? |
#14 | |
#15 |
Where did you get the price of $199 from? That doesn't sound like a BMW dealer price.
Also, what model do you have? I can't help if your ride is listed as an Acura CL, lol. |
#16 |
#17 |
I got my reman's for 89$ a piece
They've been fine so far 5k miles
![]() Need a bearing tool in Chicago-land ?http://forum.e46fanatics.com/showthread.php?t=964450 Find bmw wheel style here http://forum.e46fanatics.com/showthread.php?t=987999 |
#18 |
what brand? or did you just use your oem axles? what is the life expectancy of reman using your oem axle?
#19 |
UPDATED with correct year&model
$199 looks like it may be a replacement CV only? Here's a new oem cv for $113. http://www.getbmwparts.com/parts/200...JOINTSComplete axles are more like $350ish, but there may be chaper sources [and I'd really like to know who they are!] Last edited by APKhaos; 02-15-2013 at 11:27 PM. |
#20 | |
