///M3 Forum
Old 02-15-2013, 10:30 PM   #1
Ecko
My Ride: 2003 M3
Exclamation Advice: 2000 bmw m3
Hi
I've found an M3 with alright mileage, competitively priced (for the NZ market) and a good service history.
It's also built in November 2000.
http://bmwvin.com/?vin=JR00024&confirm_code=yngwh
There are a few things I'd like your input on.
Firstly, the build sheet says it has a "low compression engine" - what does this mean? A local BMW enthusiast said it's probably a mistake on the build sheet. I'll ask the dealer to confirm whether it is low compression or not when I get pre-purchase check but what is the LC engine?
Secondly, I was looking at the UUC short shifter kits, (http://www.turnermotorsport.com/p-12...it-e46-m3.aspx)
And it says that it fits 2001-2006 M3. Will this not fit the 2000 year or is this a mistake?
Any other points of interest on the car?
It has spec which I like:
Carbonschwarz Metallic paint
Cinnamon Nappa leather seats
6 Speed manual
Sunroof
Rear sunblind
CSL splitters
Carbon fog light covers
I'll be updating all the lights to facelift, and giving the car a general freshen up if I get it but I'd appreciate your input!
Note:
I am in New Zealand!
Ecko is offline   Reply With Quote
Old 02-15-2013, 10:39 PM   #2
Alan
Alan's Avatar
My Ride: 2006 M3
Its just a designation for your build sheet. Not the sign of any issue.
Note: US build sheets do not reflect this.
Alan is offline   Reply With Quote
Old 02-15-2013, 10:42 PM   #3
emax
My Ride: 06 M3
2001 was the first year of this model, and the first ones were built in 2000.
'06 CB/IR w/SMG/NAV/HK/19" BBS RGR/Hankooks
emax is offline   Reply With Quote
Old 02-15-2013, 10:46 PM   #4
Ecko
My Ride: 2003 M3
So the SSKs that say 2001+ will fit the car?
I suppose built 2000, register 2001 initially?
Old 02-15-2013, 11:03 PM   #5
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Your part designation 2001-2006 is the model year designation, not the manufacture date.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 02-16-2013, 12:40 AM   #6
Guest021715
Account closed.
ITT: OP is retarded.
Old 02-16-2013, 12:42 AM   #7
Ecko
My Ride: 2003 M3
Thanks for creating such a welcoming environment.
Old 02-16-2013, 09:22 PM   #8
Hacksaw
My Ride: 2002 Imola Red M3
You pretty much sum this forum up lately.
Try http://www.m3forum.net
Usually a lot more welcoming than this forum has become.
Hacksaw is offline   Reply With Quote
Old 02-16-2013, 09:23 PM   #9
Ecko
My Ride: 2003 M3
Was that directed at me summing up the forum or the ac_2007 gent?
Old 02-17-2013, 11:06 AM   #10
emax
My Ride: 06 M3
Yes on the ssk, but you can call the vendor if you want to be sure. Since the e46 model ended before the M3 some list parts for 2001-2005 but they fit the 2006 also.
Here in the US we register based on model year not manufacture date. The first models are always released one year early.
Old 02-17-2013, 03:31 PM   #11
choxor
My Ride: JDM
SSK will fit. Cinnamon interior is really nice. Be sure to get the subframe checked.
Old 02-19-2013, 02:10 AM   #12
Ecko
My Ride: 2003 M3
That particular car has now gone off my radar as it was a bit've a dog.
Got my eye on a Phoenix Yellow, 35,000kms (20k miles?), manual, no sunroof, cloth seats..
Main reason I'm lovin' it is because of the mileage!
Old 02-19-2013, 08:22 AM   #13
choxor
My Ride: JDM
Cloth interior is nice. Just be sure to get a PPI done or else you may inherit a costly mess.
Old 02-19-2013, 09:08 AM   #14
Zettinger
My Ride: //M346 vert
This one?
http://www.trademe.co.nz/motors/used...-564076707.htm
I love the e9X wheels on it!!!
Zettinger is offline   Reply With Quote
Old 02-19-2013, 09:19 AM   #15
cak323i
My Ride: ///M3 & 330i ZHP
Originally Posted by Zettinger View Post
This one?
Looks like a really nice ///M If that's the car you're looking at, good luck OP!
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 02-19-2013, 09:40 AM   #16
ChrisRedmon
My Ride: 2002 PY ///M3
Yes to the PY
What do you mean your going to facelift the car?......I hope you mean taillights only.
2002 Phoenix Yellow E46 M3 l 6MT l Nappa l Nav l STG Coilovers 7k/8k l BMW Performance SSK l OEM ZCP's l Kirk Roll Bar l Motorsport Hardware l Besian Systems l CSL/GTR Carbon Fiber Hood, Trunk & Diffuser l Status Gruppe Sec. 3 l Custom Rear Brace l Rear Seat Delete l Coby Wheel Products
ChrisRedmon is offline   Reply With Quote
Old 02-19-2013, 09:49 AM   #17
MathewM3
My Ride: BMW M3 E46
Check maintenance history, especially rod bearing recall, Here in the U.S its SIB#11-04-04 LBL code 422 M3 S54 Conn rod bearing e46 M3. Also if you could have an inspection done including taking the valve cover off to inspect the Vanos hub. The first models of M3:s seems to have more problems with broken tabs
Name:	broken vanos hub.jpg
MathewM3 is offline   Reply With Quote
Old 02-19-2013, 03:32 PM   #18
Ecko
My Ride: 2003 M3
I'll be having it PPId by a BMW Dealership.
Facelift lights only, should've clarified that
And yes, that's the one! You're onto it!
Old 02-19-2013, 06:19 PM   #19
YYCBMW
My Ride: 2003 M3 Convertible
Just to confirm the above, I own a 2000 328CI and the build date was November 1999.
YYCBMW is offline   Reply With Quote
