Thread Tools Search this Thread Rating: Thread Rating: 26 votes, 5.00 average. Display Modes
Old 04-11-2013, 04:52 AM   #61
02PRUV
My Ride: E46 M3 Turbo
Well I just waiting on a corvette filter/reg and this would be running. Only got a little wiring and clean up to do now. Nothing that will stop me starting it anyway.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 04-11-2013, 09:39 AM   #62
Cruzader
My Ride: Alpinweiß facelift
it's buriful
Cruzader is offline   Reply With Quote
Old 04-11-2013, 10:21 AM   #63
Brevik
My Ride: Tiag M3
Wow, the exhaust is amazing.
Brevik is offline   Reply With Quote
Old 04-16-2013, 05:12 PM   #64
02PRUV
Well I'm still waiting on this fuel filter/reg to turn up so I decided to knock over the shifter.
List of things to finish is small now:
Wire tach
Wire fuel pump
Wire oil temp and level light
Install fuel filter/reg
Bleed brakes
Install heat sheilding
Once these things are done then it's wait for the big engine to arrive.
Rides:
Old 04-16-2013, 05:39 PM   #65
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
02PRUV, I'm sure you've seen it but someone on bimmerforums reverse engineered the CAN for the E46 Cluster so he could use the cluster with his LS swap. You should check it out, the guy is pretty open about sharing his findings.
Old 04-16-2013, 06:53 PM   #66
02PRUV
Yeah I've seen it. Good on him for putting the effort in but I personally think it's a lot of time and trouble for nothing when you can use the DME as your canbus interface and have everything work still
Rides:
Old 04-16-2013, 07:18 PM   #67
BWOODM3
My Ride: 2002 M3 convertible
Wow this is crazy. Can't wait for sound clips and vids.
BWOODM3 is offline   Reply With Quote
Old 04-16-2013, 09:10 PM   #68
MarcusLSB
I guess I'm not sure how the DME hooks up to the LS motor. Are the sensors compatible and do they have the same range? Does the DME get pissed that its not controlling anything?
The beauty (other than the fact he's already done the work for you) of using his approach is you don't need the dme, instead just a small embedded (or aurdino controller w/can shield) and all your sensors work like stock, and if he gets the CAN reverse engineered from the GM ECU I'm assuming he'll even be able to use the stock check engine light.
But yes.. it is a TON of work.. I wouldn't recommend someone do it .. but being someone has already done it, imo it would be silly not to use his code. Sounds like he might even sell a completely finished product being his son is now removing the can chips off the can shield's and it sounds like he might be making his own board for it. I think its bad ass!
Old 04-16-2013, 09:21 PM   #69
02PRUV
If he is going to do that then it's a bonus. Buy it and plug it in. Then I would suggest doing this and I would buy one myself. The only other issue is he is only doing a 3 series not an M. Gauges are all different and CAN messages are different between models and between year models on some vehicles. So it will be a lot of work for him to sell these to everyone.
The DME doesn't care that it's not controlling anything. I had the DME already just doing the dash in my car with the turbo setup cause my ViPEC ecu did all the engine stuff.
Rides:
Old 04-16-2013, 11:19 PM   #70
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Technically the dash in E46s is the CAN BUS gateway. If you pull the dash, you'll find that lots of other stuff doesn't work.
In some cars the gateway is the ECU, others it's a dedicated box on it's own.
What I'm most excited about is the coming range of dash display products that will use relatively cheap LCD displays, like iPad Mini, acting through a bluetooth adapter. That...and Motec's new stuff that may have flexible CAN integration.
Old 04-16-2013, 11:21 PM   #71
MarcusLSB
Right, I get that, same as my car. But that was with a S54 motor I thought. If you swap the motor can you literally plug the stock dme into the oil temp sensor, etc and it just reads it like no problem, do the sensors have the same range/readings, are you reusing the same sensors? Or am I just very confused.
Old 04-17-2013, 12:10 AM   #72
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
wow, cool project - in for further details
/_________\
O==[][]==O
Old 04-17-2013, 12:41 AM   #73
02PRUV
Use the BMW sensors in the LS. So it's the same sensors connected to the DME and controlling the dash
Rides:
Old 04-17-2013, 12:45 AM   #74
02PRUV
I was just talking about the DME being the CAN interface for the engine sensors to the dash.
Rides:
Old 04-17-2013, 12:59 AM   #75
MarcusLSB
Ok gotcha, cool!
Old 04-17-2013, 01:22 AM   #76
Big McLargehuge
My Ride: 2004 325ci
Sub'd for later...
Big McLargehuge is offline   Reply With Quote
Old 04-19-2013, 07:55 AM   #77
02PRUV
And it's alive!!
Now just have tidy up, do some A/C lines and get the A/C working and some heat sheilding.
I will get the oil temp working on the dash when I do the engine swap over. I will also do a remote bleeder on the slave cylinder because the bleeder is near impossible to get to. Other than these things it's all running and driving. I can't wait for the big engine though. I forgot how gutless stock LS1's are
I also made some changes to my twin in-tank pump setup. Instead of having to pumps t'ed in-tank, I have run two bulkhead fittings on the hanger lid. Now I also have braided teflon hose right from the pumps to the engine and to the return. I have t'ed the lines above the return side of the tank because there is no room anywhere else and I didn't want to do it under the car.
Rides:
Old 04-19-2013, 08:44 AM   #78
330i ZHP
330i ZHP's Avatar
that sounds great
I should pull the SC'd 3.0L out of my touring and do this
/_________\
O==[][]==O
Old 04-19-2013, 08:55 AM   #79
FragNasty
My Ride: Car
Damn!
FragNasty is offline   Reply With Quote
Old 04-19-2013, 09:04 AM   #80
E85head
My Ride: E46 M3
That project went quick!
E85head is offline   Reply With Quote
