Sponsored by BimmerWorld
Old 02-16-2013, 08:36 PM   #1
Flaboy239
My Ride: 2004 330ci
Traction control light on...
Car was parked for a few weeks and upon starting it the light came on and traction control is always in off mode. Is it a sensor or switch that went bad? Where can I find the part?
Flaboy239 is offline   Reply With Quote
Old 02-17-2013, 12:28 AM   #2
My325XI
My Ride: 03 325XI Sprt Prem
If the light is ON, then the DSC system is off. Hit the DSC button to see if the dash light goes on/off.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 02-17-2013, 08:46 AM   #3
Flaboy239
My Ride: 2004 330ci
Dude, I'm not stupid.
Old 02-17-2013, 09:23 AM   #4
HiHoBrian
My Ride: 05 M3
It could be one of the two speed sensors,the steering angle sensor,or even a fault within the DSC module. Your best bet is to scan it with PA Soft scan tool. A generic obd2 scanner won't help here. You can check the speed sensors with a volt meter by spinning the wheel and testing for voltage,but the scan tool is a much easier method.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 02-17-2013, 07:36 PM   #5
TalinBolen
My Ride: E46 325ci
This happened to me and it was from a brake fluid leak. If it got to low it would shut off the dsc. ended up that my clutch master cylinder was done and leaking fluid on the pedals. That's just what happened to me but it's worth a glance I'd say.
TalinBolen is offline   Reply With Quote
