Old 02-16-2013, 11:13 PM   #1
jaswild
My Ride: 2005 BMW 325i
Unleaded or premium
Am I being uptight or should I only use premium in my E46? Is regular fine? I have been religious about using premium, but with the rise in gas prices...
jaswild is offline   Reply With Quote
Old 02-17-2013, 09:25 PM   #2
j_block
My Ride: 2003 325i
Don't buy a bmw if your concerned about cheap gas
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 02-17-2013, 10:20 PM   #3
WALKD U
My Ride: Just Fast!
Premium or 100 OCT
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-18-2013, 12:23 AM   #4
09f800st
My Ride: 2004 325I 2009 F800
Just for the sake of argument...I filled up the car with regular (87 octane), gave it to Wifey, and sent her to Portland on a shopping spree.
She came home with 418 miles on the car....averaged 34.6 miles per gallon.
I normally run premium, but I'm switching it up now and again, based on my own results. Yours may vary
09f800st is offline   Reply With Quote
Old 02-18-2013, 12:43 AM   #5
36Daytona36
My Ride: E46 M3
Isn't the peace of mind worth the extra $3 a tank?
36Daytona36 is offline   Reply With Quote
Old 02-18-2013, 12:44 AM   #6
WALKD U
My Ride: Just Fast!
Yep, when motor start knocking. Say bye bye to motor
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 02-18-2013, 12:59 AM   #7
36Daytona36
My Ride: E46 M3
I hate when people complain about having to put premium in. Its $3 more a tank in gas. Its suppose to give you better MPGs and burn cleaner in your engine. Think of all the things you dont need that you regularly buy and how much that costs.
Old 02-18-2013, 01:10 AM   #8
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
No kidding. Wtf.
"Hey guys. So I'm trying to find ways to save $4.56 a month. Is it totally cool if I use unleaded against bmws recommendation? I plan on starting a college fund for my kids with the saved money."
Old 02-18-2013, 01:57 AM   #9
jaswild
Wow, sorry to get your panties in a bunch guys. I found the thread I should have read first before having to deal with your opinions... I'll do better digging next time before I prod old wounds.
Old 02-18-2013, 08:31 AM   #10
09f800st
It's a tough crowd to be sure...Gotta have thick skin if you want to keep your sanity
But there are some misconceptions;
First...premium burns no more dirty or clean than any other octane rating.
Premium and regular both create the same amount of energy when burned. Premium just burns slower allowing for higher compression and more advanced timing, which in turn allows for more horsies from your car.
The simple answer is that if the manufacturer says use premium, then that's what you should use. Will your motor blow with regular? NO
Old 02-18-2013, 09:32 AM   #11
GTB323
My Ride: 2000 323ci
Correct me if I'm wrong but doesn't premium "burn more complete" therefore leaving less cArbon buildup in your engine?
GTB323 is offline   Reply With Quote
Old 02-18-2013, 09:36 AM   #12
09f800st
That's a misconception
Gasoline pumps typically post octane numbers as an average of two different values. Often you may see the octane rating quoted as (R+M)/2. One value is the research octane number (RON), which is determined with a test engine running at a low speed of 600 rpm. The other value is the motor octane number (MON), which is determined with a test engine running at a higher speed of 900 rpm. If, for example, a gasoline has an RON of 98 and a MON of 90, then the posted octane number would be the average of the two values or 94.
High octane gasoline does not outperform regular octane gasoline in preventing engine deposits from forming, in removing them, or in cleaning the engine. Consumers should select the lowest octane grade at which the car's engine runs without knocking. Occasional light knocking or pinging won't harm the engine, and doesn't indicate a need for higher octane. On the other hand, a heavy or persistent knock may result in engine damage.
Old 02-18-2013, 09:43 AM   #13
Brevik
My Ride: Tiag M3
I ran unleaded 87 octane in my 323ci for years with no issues and averaged 30 mps the whole time, however I do use 93 octane in my M3.
Brevik is offline   Reply With Quote
Old 02-18-2013, 10:01 AM   #14
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Definitely should use UNLEADED! All BMWs use Unleaded. I am not even sure anyone sells Leaded fuel anymore.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 02-18-2013, 10:14 AM   #15
e46jki44
My Ride: e46 325i sedan
Most gas with octane levels over 100 is leaded but is only for offroad use and on cars with no catalytic converters.
Sent from my SPH-D710 using Bimmer App
e46jki44 is offline   Reply With Quote
Old 02-18-2013, 10:24 AM   #16
BMWCaptain
Where do they sell 100 octane?
BMWCaptainE46.com
Old 02-18-2013, 12:12 PM   #17
peytonracer4
:D
My Ride: '00 328i
There's a station near me that sells 100. Not sure if its leaded because I've never really look at it
Old 02-18-2013, 02:23 PM   #18
e46jki44
A few gas stations have 100 near me. It is still unleaded. When you get into higher octanes like 110 and up it can be found at race tracks.
Old 02-18-2013, 09:39 PM   #19
genuity
My Ride: 2001 330iS
The engine was designed for 91 octane. Just use what was recommended by the manufacturer. Penny pinchers need not apply but consider it the BMW "tax." I think we have all been down this road at one point or another to either have not filled up with premium or have thought about it. You have to pay to play, right?
Read these:
http://www.caranddriver.com/features/regular-or-premium
Stan Baldwin, BMW Spokesperson - Running On Regular: Do Premium Vehicles Really Need Premium Gasoline?
http://www.roadandtrack.com/car-news...m-fuel-futures
genuity is offline   Reply With Quote
Old 02-18-2013, 10:22 PM   #20
09f800st
It's the same thing I just said...only waaaay more wordy. I don't work for Car and Driver, but I did stay in a Holiday Inn last night
