Old 02-17-2013, 12:30 AM   #1
Species0113
My Ride: 2001 BMW 330CI
BMW Scanner 1.4.0 or Dealer flash?
Are there any guides or instructions for the BMW scanner 1.4.0? Or does it come with some sort of instructions? Also, will my Shark tune conflict with the BMW scanner 1.4.0 rewrite? I'm not sure what all info the Shark saves or rewrites but I'm not trying to buy another one. Finally got a complete oem xenon setup w/ A/E's pieced together. Just trying to decide on the BMW scanner vs. the dealer flash. Thanx in advance
Species0113 is offline   Reply With Quote
Old 02-17-2013, 02:28 AM   #2
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
If all you need is to flash/recode from halogen to HID, there shouldn't be a problem. I don't know what capabilities BMW Scanner has, but it's simple with GT1. (INPA/DIS/GT1)
There are several fanatics in PA that might be able to assist you.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 02-17-2013, 08:39 AM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
It would be easier to answer if you can clarify what it is that you want to do.
If all you are doing is changing headlights from halogen to Xenon, it would be very easy to just check xenon for your lighting control and re-program your car with the BMW scanner 1.40.
If you want to re-program your engine tune that will be a little more complicated. You would have to save your current setup so you can restore it. You would re-program your engine control with whatever new tune you wanted. If it does not work, then restore your old setup.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 02-17-2013, 05:17 PM   #4
Species0113
All I want to do is swap out my halogens for the xenons and re flash it. Just making sure I can do it myself with the BMW scanner 1.4 or will I have to get the dealer to do it. I currently have a shark tune on it and wanted to make sure the flash did not affect that. I am just not familiar with the flash process as far as if you can choose what gets flashed or if its a complete rewrite of the ecm.
Old 02-17-2013, 05:28 PM   #5
BMWCaptain
It is very easy to do with Scanner v1.40 . You are not touching many of your subsystems, so your tune will not be affected. All you will be doing is changing you Lighting Control Module setting to tell it what kind of lighting you have. It is as simple as checking Xenon and saving.
BMWCaptainE46.com
Old 02-17-2013, 05:44 PM   #6
Species0113
Sweet. thnx. Just ordered the scanner.
