Old 02-17-2013, 08:45 AM   #1
hogson
My Ride: 1999 323i
help- cooling system problems
yesterday i was driving the car semi-hard, and shortly after while still driving the low coolant light came on. i was 2 minutes from destination so i continued on and assumed it wasnt anything horrid since the temperature gauge was not really too high. a belt started squeaking at every stop sign along the way, which im assuming is because of the coolant splattered all over it. anyway when i parked there was steam coming from under the hood..tons of it. opened the hood to find coolant all over the place, and all over the ground and well as trailing to my spot, and the radiator hose to be soft and squishy. now knowing the severity of this i called my dad who drove my other car over and switched cars with me and filled mine with his left over mercedes coolant to slowly make it home. i didnt get home till around 1 so i did not try ti diagnose anything..now its daylight out and i need to know what to look for? and how to determine if its a water pump, expansion tank, etc. causing this.
1999 323i -5 speed.
1985 Buick Lesabre coupe.
hogson is offline   Reply With Quote
Old 02-17-2013, 08:49 AM   #2
tommy d
My Ride: 2005 330i
Based on what your describing, your going to need to flush the coolant with new BMW coolant, and while you are it, find what caused your leak. But even though I would only recommend swapping what failed, in your case I'd replace the water pump, hoses, expansion tank and thermostat. Basically the "coolant repair kit" sold by many online vendors.
Current Vehicles in my stable:
2005 BMW 330i - 126K miles
2005 Mazda Tribute s - 117K miles
1998 Ford Taurus SE - 115K miles
1987 Ford Mustang LX 5.0 - 248K miles
tommy d is offline   Reply With Quote
Old 02-17-2013, 08:55 AM   #3
college46
My Ride: Alpine White
See here, there is literally years of information for our "Cooling system" just search for it.
http://forum.e46fanatics.com/showthread.php?t=914109
My guess is a crack in the e/t without looking at any pics.
Can you post pics?
Going to Bimmerfest West
01 325i ZPP 5 speed, 101,xxx
college46 is offline   Reply With Quote
Old 02-17-2013, 09:01 AM   #4
RayPooley
My Ride: 320i SE Coupe
You can "flush" it with water. Although not sure what flushing it will do. When you are ready to refill then use the proper spec coolant. BTW hot hoses can be expected to be a little soft when not pressurized. Not necessarily a problem.
Old 02-17-2013, 12:51 PM   #5
hogson
My Ride: 1999 323i
expansion tank is out now- has a hole in it. seems the date on the tag is 5/13/08 so im assuming its the cars second one. should i still do the thermastat, etc?
1999 323i -5 speed.
Old 02-17-2013, 01:01 PM   #6
Cpconst
My Ride: 2004 e46 m3
I'd would replace as many components as you can afford to if you're not sure which ones were replaced within the last 60,000 miles.
Cpconst is offline   Reply With Quote
Old 02-17-2013, 01:31 PM   #7
jfoj
My Ride: 330CiC, M5, X5
Read 3rd link below in my signature.
Old 02-17-2013, 01:47 PM   #8
WDE46
My Ride: '13 128i, '04 330Ci
JFOJ's link is the best information here. Read about the cooling system and learn as much as you can. Decide for yourself if you want to just overhaul it. Whether you do this yourself or have a shop do it, make sure they fill the system to the correct level and bleed it properly. It is amazing how many "BMW" shops don't actually know how to fill the M54 cooling system. Check it yourself or suffer the consequences.
Old 02-18-2013, 07:27 PM   #9
hogson
My Ride: 1999 323i
do i need to get BMW specific coolant? and what exactly is the proper way to bleed it? is it not done like most other cars?
1999 323i -5 speed.
Old 02-18-2013, 07:35 PM   #10
hogson
My Ride: 1999 323i
found a page on proper bleeding.
1999 323i -5 speed.
