Old 02-17-2013, 10:45 PM   #1
THECLEANERBEAMER
My Ride: 2002 325i
Need help with my retrofit
Alright guys I hooked up my mini morimoto projector with morimoto h1 hids and with wire harness. I know I will need coding, but I wanna make sure I hooked up the wire harness to the ballast to the projectors right. So can anyone post pictures of there wire harness set up? Perferably the retrofit source wire harness
Thanks!
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
Old 02-18-2013, 06:29 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
- Red power wire to the battery terminal near the drug bin
- Ground wire to the big nut in the drug big
- Male ends go to ballasts
- Female ends to factory harness
Old 02-18-2013, 07:15 AM   #3
THECLEANERBEAMER
My Ride: 2002 325i
See that's the problem I have nothing left to connect to the original h7 low beam connector
Old 02-18-2013, 07:21 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
Can you post pics of the harness and all of its connectors?
Old 02-18-2013, 08:08 AM   #5
THECLEANERBEAMER
My Ride: 2002 325i
See nothing connected to low beam
Ground.
Power it's disconnected right now
Ground #2
Connection from relay to ballasts
From ballasts to h1 bulbs
And other free low beam connector
Old 02-18-2013, 08:10 AM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
Interesting. Which harness did you get?
Old 02-18-2013, 08:12 AM   #7
THECLEANERBEAMER
My Ride: 2002 325i
Also have this don't know what it is
Guessing for bixenon feature?
Old 02-18-2013, 08:13 AM   #8
THECLEANERBEAMER
My Ride: 2002 325i
The morimoto heavy duty harness
Old 02-18-2013, 08:19 AM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
I think you might have the wrong harness. I was looking at their site and I can't find the one you have.
Old 02-18-2013, 08:30 AM   #10
sandman512
My Ride: 2005 325I
Solid,
Not to thread jack, but shouldn't this set up be a PnP to his stock wiring harness via the ballasts?
When I did my P46's, ballasts/igniters went directly to harness(stock).
Thanks!
sandman512 is offline   Reply With Quote
Old 02-18-2013, 08:31 AM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yes he can.
Old 02-18-2013, 08:39 AM   #12
THECLEANERBEAMER
My Ride: 2002 325i
Yeah I can anyways I ordered the standalone canbus harness from the retrofit source
Old 02-18-2013, 09:16 AM   #13
THECLEANERBEAMER
My Ride: 2002 325i
btw jake i was looking on their website and i think they sent me the motorcyle dual h7 lamp harness
Old 02-18-2013, 04:24 PM   #14
THECLEANERBEAMER
My Ride: 2002 325i
ok so since i have a motorcycle wire harness lol i just wired it straight to the ballasts they work but they flicker after a bit so hopefully the canbus standalone harness thats on its way will fix that with out me coding my car
Old 02-18-2013, 05:06 PM   #15
sandman512
My Ride: 2005 325I
Nice clean look. How was it getting the shrouds on? Any filing? Any input appreciated.
Thanks!
Old 02-18-2013, 11:52 PM   #16
THECLEANERBEAMER
My Ride: 2002 325i
I super glued the centric ring that goes on the shroud then I put epoxy on the plastic around the projector and then put the shroud on
Old 02-19-2013, 09:03 AM   #17
Solidjake
Zero. Leaks.
Solidjake's Avatar
Looks good
Old 02-19-2013, 09:11 AM   #18
THECLEANERBEAMER
My Ride: 2002 325i
Thanks I was watching your video the entire time I was doing the retrofit lol
Old 02-19-2013, 09:12 AM   #19
Solidjake
Zero. Leaks.
Solidjake's Avatar
Old 02-20-2013, 04:25 PM   #20
THECLEANERBEAMER
My Ride: 2002 325i
Just installed from the retrofit source some morimoto canbus stand alone harnesses and now there is no more flickering or errors on dash! And didn't even need to code
