Sponsored by BimmerWorld
Old 02-18-2013, 05:55 AM   #1
SergiCompact
My Ride: E46 318ti Compact
Rear Suspension Overhaul
Hi guys I want to replace the suspension of my car and I am pretty sure what to do in the front. With ZHP arms and Meyle HD FCABS, Then Meyle Tie rods and new struts with strut mounts.
But the rear I am not sure what is worth to replace any clues?
Building the 330Ti! See my thread!
http://forum.e46fanatics.com/showthread.php?t=964911
SergiCompact is offline   Reply With Quote
Old 02-18-2013, 09:45 AM   #2
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
shocks
upper shock mounts and nuts
upper shock mount seal
lower shock bolts
RTABs - lots of people like the two-piece Powerflex bushing. Make sure you get a good tool like the MIS tool for removal (and install, if using a one-piece bushing). Pre-load alignment is also critical when re-installing the mounting bracket around the new RTAB.
There are plenty of DIYs on this site for replacing all of the above. Just search!
Old 02-18-2013, 02:27 PM   #3
SergiCompact
Originally Posted by LeMansteve View Post
shocks
lower shock bolts
Thanks man... That is the obvious and I will throw in a complete Bilstein coilovers, But I belive it's not enough I think I will need to change the subframe bushes as well and I am not sure which RTABS are the best some people upgrade to M3 RTABS and others to Powerflex
Old 02-18-2013, 03:51 PM   #4
LeMansteve
You can't go wrong with any of those RTABs. Keep in mind you probably have to lube the polyurethane Powerflex bushings periodically to prevent squeaking. Personally, I would just install identical BMW non-M3 RTABs. IMO when the original RTABs are worn out, sometimes people forget just how good they were when new. Then they go overboard with a super-stiff bushing.
