Old 02-18-2013, 10:06 AM   #1
icecolde46
My Ride: e46
Talking what is the connection between cold start misfire and Second Air Pump?
I have tried to replace a lot parts for my 2000 323i and the cold start misfire problem still happens.
I am very positive that the more cold the temp is (around 32F), the misfire seems worse.
I got only random misfire codes, a strong feeling of car shaking, and a big smoke out of the tail pipe.
And today, fortunately, I got a new code hopefully providing me more clues. It is p1421.
I have read some threads on this forum. this one shows exactly the same symptoms as mine. it is a bad sap.
http://www.e46fanatics.com/forum/sho...d.php?t=852552
I am not sure how SAP can affect the cold start misfire.
icecolde46 is offline   Reply With Quote
Old 02-18-2013, 12:22 PM   #2
Zchild
My Ride: 2000 BMW 3XXi ZSP
Before you replace the SAP I would check the vacuum line that runs from the SAP to the rear of the motor... It can become brittle and break in sections which can cause misfires. It is a little difficult to reach the portion behind the motor. Just my two and a half cents worth!
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 02-18-2013, 01:04 PM   #3
dreyo27
My Ride: 2001 325ci
Originally Posted by zchild View Post
before you replace the sap i would check the vacuum line that runs from the sap to the rear of the motor... It can become brittle and break in sections which can cause misfires. It is a little difficult to reach the portion behind the motor. Just my two and a half cents worth!
thats what i had... I ripped it when i was doing my vcg
dreyo27 is offline   Reply With Quote
Old 02-18-2013, 01:52 PM   #4
Zchild
Cool
I disconnected my vacuum hose while replacing my VCG as well and had the accompanying CEL...
Old 02-18-2013, 04:13 PM   #5
rudycoop
My Ride: 3 pedal 330i
There is a switch that runs the vacuum that opens the check valve to allow the SAP to blow air into engine. If any of those aren't working right you could have that problem. I had the code and it was 2 hoses broken. The switch is under the back of the intake manifold. Don't just check around the valve cover, because mine was broken at the switch under the intake. I have big hands and it was a little of a pain to work with. You definitely have to take the cabin air filter assembly out and the black plastic wall that pulls out.
rudycoop is offline   Reply With Quote
Old 02-18-2013, 05:16 PM   #6
jfoj
My Ride: 330CiC, M5, X5
Suggest you read the first link below in my signature for more info.
cold start
