Sponsored by BimmerWorld
Old 02-18-2013, 10:13 AM   #1
Nike11
My Ride: 2000 328i
Bad front control arm
I have been reading a lot about what brand is best and most reliable and I am thinking of getting mayle hd kit to replace my shot ones. Would these be good to get cause I have read that the fcabs make some road noise? I just want to make sure I order everything before I take it to the shop to fix.
E46
Nike11 is offline   Reply With Quote
Old 02-18-2013, 12:52 PM   #2
ModBargains III
ModBargains III's Avatar
My Ride: E46
FCAB's don't make noise if you get a good set, like powerflex which you can find right here, we've got them in stock, ready to ship:
PowerFlex Urethane Suspension Bushings E46 Non-M/M3
If you have any questions, feel free to ask!
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
Old 02-18-2013, 02:30 PM   #3
Nike11
My Ride: 2000 328i
So if when i get new FCABs i would have to take the ones out of the Mayle hd kit i order right? or should i just go with OE replacement from autopartwarehouse?
E46
Old 02-18-2013, 02:34 PM   #4
ModBargains III
My Ride: E46
OE is a rubber compound, which over time will dry out, rot, and then not perform as well as the polyurethane bushings that I can provide for you. Bushing replacements are fairly easy for any shop to do, I'd expect the fronts to not take more than 1 hour.
Hours
Old 02-18-2013, 02:43 PM   #5
Nike11
My Ride: 2000 328i
Are the FCABs that come with the Mayle Kit rubber?
E46
Old 02-18-2013, 10:42 PM   #6
Whinojosa
My Ride: 2004 BMW 325i
Meyle are rubber - just a slightly different/stiffer compound than OEM. These will have similar wear and handling characteristic.
Polyurethane (such as the P-Flex from ModBargains) will be longer lasting, yet harsher. I've got Rogue's polyurethane "Street" FCABs and personally don't notice a harsher ride. Modbargains has these too http://www.modbargains.com/Rogue-Eng...6-E36-FCAB.htm
Whinojosa is offline   Reply With Quote
