Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Southeast
Southeast
AR AL GA FL KY LA MS NC SC TN
Old 02-18-2013, 11:20 AM   #1
clemsone46
My Ride: 2014 DCSB, 2005 ZHP
Huge parts cleanout: E30, E36, E46 parts. CHEAP
E36 AC compressor: $40
E36 starter (from M52): $15
OTHER ITEMS
E30 lock cylinder (new): $10
E30 clutch stop: $5
E30 door plunger: $1
E30 trunk plunger: $1
M20 valve seals (new): $5
M20 valve cover: $10
E30 unlit window switches (3): $1 each
Hazard switch: $1
M20 oil cap (new): $5
BRAND NEW PARTS:
E30 Clutch master cylinder: $30
E30 OEM air filter: $5
E46 automatic transmission filter and pan gasket: $20
M50/M52/S50/S52 front crankshaft seal: $5
M50/M52 oil cap: $8
Temp sensor: $8
Temp sending unit (for 24v swap): $8
Aux fan switch: $8
E30 AC belt: $5
Please let me know if you have any questions.
clemsone46 is offline   Reply With Quote
Old 02-18-2013, 07:41 PM   #2
nanpat
My Ride: 325i
Yaw Speed Sensor
Hi there, would you have a speed sensor #3452-6 754 289 ? I have a2001 325i and the part was damaged, the dealer is so expensive.
Thanks,
Nancy
nanpat is offline   Reply With Quote
